Marco A. Turcios
Rep Power: 28 ![]() |
In continuing my exploration of the new lagrangian spray libraries, I've tried to run sprayEngineFoam with a profile I've used before to simulate diesel injection. However, there is no injection at any time during the run.
I think it may have to do with the mapping from crank angle to seconds. In the old dieselSpray libraries there was mapping done with userTimeToTime so that the profile can be specified in crank angle degrees (which is pretty standard), which I haven't been able to find yet in the new libraries. Right now I've specified SOI, duration and profile in CAdegrees and get no injection. Is there another combination I should try? I would think specifying everything from the dictionary in crank angles makes the most sense. I don't know if this qualifies as feature request or bug report, so I'll leave it here for consideration. |
Marco A. Turcios
Totally forgot I hadn't reported; there was indeed a problem with the crank angle mapping. The version currently on git is working properly.
Rep Power: 10 ![]() |
Dear Foamers,
I'm a bit stuck trying to run sprayEngineFoam with fuel injection. I set up my case as a mixture of the aachenBomb lagrangian tutorial and the one regarding engineFoam. Both based on OpenFOAM versions 4 and 5. Annoyingly, no fuel is injected and albeit thourough investigation I did not find a solution, yet. I hope some of you can help me. So, here's a snippet of the output of OpenFOAM during runtime: Code:
Courant Number mean: 0.00010521857883 max: 0.197815497257 deltaT = 1.20141012565e-06 Crank angle = -179.594698012 CA-deg deltaZ = 1.09762120504e-07 DICPCG: Solving for yPsi, Initial residual = 9.03191839263e-09, Final residual = 9.03191839263e-09, No Iterations 0 clearance: 0.204997915028 Piston speed = 0.0913610749238 m/s Solving 2-D cloud sprayCloud Cloud: sprayCloud Current number of parcels = 0 Current mass in system = 0 Linear momentum = (0 0 0) |Linear momentum| = 0 Linear kinetic energy = 0 model1: number of parcels added = 0 mass introduced = 0 Parcel fate (number, mass) - escape = 0, 0 - stick = 0, 0 Temperature min/max = 0, 0 Mass transfer phase change = 0 D10, D32, Dmax (mu) = 0, 0, 0 Liquid penetration 95% mass (m) = 0 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCGStab: Solving for Ux, Initial residual = 0.00473860342429, Final residual Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class dictionary; location "constant"; object SprayCloudProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solution { active true; coupled true; transient true; cellValueSourceCorrection true; maxCo 0.3; sourceTerms { schemes { rho explicit 1; U explicit 1; Yi explicit 1; h explicit 1; radiation explicit 1; } } interpolationSchemes { rho cell; U cellPoint; thermo:mu cell; T cell; Cp cell; kappa cell; p cell; } integrationSchemes { U Euler; T analytical; } } constantProperties { T0 323; rho0 1000; Cp0 4187; constantVolume false; } subModels { particleForces { sphereDrag; } injectionModels { model1 { type coneNozzleInjection; SOI -180; massTotal 1e-05; parcelBasisType mass; injectionMethod disc; flowType flowRateAndDischarge; outerDiameter 2.0e-03; innerDiameter 0; duration 10; position (0 0 0.2); direction (0 0 -1); parcelsPerSecond 1000000; flowRateProfile table ( (-181 0) (-180 0.3) (30 0.3) (31 0) ); Cd constant 0.9; thetaInner constant 0.0; thetaOuter constant 10.0; sizeDistribution { type RosinRammler; RosinRammlerDistribution { minValue 1e-06; maxValue 0.00015; d 0.00015; n 3; } } } } dispersionModel none; patchInteractionModel standardWallInteraction; heatTransferModel RanzMarshall; compositionModel singlePhaseMixture; phaseChangeModel liquidEvaporationBoil; surfaceFilmModel none; atomizationModel none; breakupModel ReitzDiwakar; stochasticCollisionModel none; radiation false; standardWallInteractionCoeffs { type rebound; } RanzMarshallCoeffs { BirdCorrection true; } singlePhaseMixtureCoeffs { phases ( liquid { C7H16 1; } ); } liquidEvaporationBoilCoeffs { enthalpyTransfer enthalpyDifference; activeLiquids ( C7H16 ); } ReitzDiwakarCoeffs { solveOscillationEq true; Cbag 6; Cb 0.785; Cstrip 0.5; Cs 10; } TABCoeffs { y0 0; yDot0 0; Cmu 10; Comega 8; WeCrit 12; } } cloudFunctions {} // ************************************************************************* // Any help is appreciated! Kind regards, Martin Last edited by NablaDyn; February 1, 2018 at 10:28. Reason: Typo |
how to inject many particles in fluent? | elah599 | FLUENT | 16 | April 21, 2017 05:18 |
Inject flow by nodes | Carlitos | CFX | 8 | January 23, 2010 07:23 |
Function to inject particles only once? | KK | CFX | 0 | March 4, 2008 15:45 |
how to inject gaseous fuel | Dinesh | Siemens | 0 | May 9, 2006 01:41 |
Inject the water bubble | summer | FLUENT | 3 | May 4, 2006 18:42 |
