OpenFOAM v.2.x Courant Number 4 time higher then in previous versions |
February 16, 2012, 04:57 |
Hi Foamers!
I got and issue using OpenFOAM v2.x: Courant Number jumps 4 times if compare to OpenFOAM v1.6 and 1.7.x. I tried cases for different geometries ofcouse with the same setting between OF versions and result is always the same! Actually this issue results in a calculation time increasing 4 times. Unappropriated! Please, comment on that issue, what is your experience with v2.x usage? Cheer, Alex
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
February 16, 2012, 07:54 |
February 16, 2012, 09:05 |
#3 | |
Issue closed (http://www.openfoam.com/mantisbt/view.php?id=424#c1039):
Will do more checks and report regarding actual calculation time.
February 17, 2012, 11:02 |
#4 | |
Alberto Passalacqua
Rep Power: 36 |
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
February 17, 2012, 15:20 |
Hi Alberto!
pimpleFoam. According to my test to keep the same Co number (with which solution does not diverge) actual calculation time increased 2 times (I remind with the same constant dt I've got Co_new_OF = 4*Co_old_OF).
February 17, 2012, 15:22 |
Slow down, to my opinion, is not 4 times because now turbulence is solved at last PIMPLE iteration. But of course I tried with turbulence updated each iteration: the same result, solution diverges with the dt I used before with old OF versions..
February 17, 2012, 21:14 |
#7 | |
Alberto Passalacqua
Rep Power: 36 |
Do you use any particular boundary condition? For example mapped, or time-varying, or custom BC? Some of these were updated in 2.x.
February 18, 2012, 06:55 |
Nope, standard k-epsilon (also tried with realizable which I mostly use) with standard wall functions for k, epsilon, nut, fixed values for U at inlet and zero gradient at outlet, pressure 0 at outlet and zero gradient at the inlet. I think it would be better if I upload here some test case. Will do it on Monday.
February 18, 2012, 21:28 |
#9 |
Alberto Passalacqua
Rep Power: 36 |
Yes, that's a good idea. The BC's are surely not the reason.
courant number, openfoam |
Very high courant number, time step continuity errors and bounding epsilon | erncyc | OpenFOAM Running, Solving & CFD | 1 | March 24, 2011 11:00 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
