simpleFoam Foam::error::printStack(Foam::Ostream&)kOmegaSSTCo effs
Old   February 23, 2012, 04:03
Default simpleFoam Foam::error::printStack(Foam::Ostream&)kOmegaSSTCo effs
Nick
Verfblikje is on a distinguished road
Dear forummembers,
I am running a 2D multi-element airfoil simulation using an o-grid. The solver used is simpleFoam and I use the kOmegaSST turbulence model.
I first tried to to this simulation in a square domain, which worked fine. However, since I need do a sweep of angles of attack I switched to a circular domain. I use the inletOutlet boundary condition. Yet, with the new domain I keep getting a printStack error. Searching the forum I did find something. But I am not sure what to do with this information. It says that the problem of the topic starter might be in grad(U_). Does this imply my U should not be a uniform field, because then grad(U_) will be zero? Or should I be looking elsewhere?
Thanks for reading and I hope some one can help.
Nick
P.S. I have attached the contents of the 0 folder to this post.
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
--> Upgrading k to employ run-time selectable wall functions
    Backup original k to k.old
    Writing updated k
--> Upgrading omega to employ run-time selectable wall functions
    Backup original omega to omega.old
    Writing updated omega
--> Creating nut to employ run-time selectable wall functions
    Writing new nut
[2] #0  Foam::error::printStack(Foam::Ostream&)kOmegaSSTCoeffs
    alphaK1         0.85034;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.85616;
    gamma1          0.5532;
    gamma2          0.4403;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    c1              10;
No field sources present
SIMPLE: convergence criteria
    field p	 tolerance 1e-05
    field U	 tolerance 1e-05
    field k	 tolerance 1e-05
    field omega	 tolerance 1e-05
Starting time loop
 in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::mag<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[2] #4  Foam::incompressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&, Foam::word const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[2] #5  Foam::incompressible::RASModel::adddictionaryConstructorToTable<Foam::incompressible::RASModels::kOmegaSST>::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[2] #6  Foam::incompressible::RASModel::New(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
[2] #7
[2]  in "/opt/openfoam210/platforms/linux64GccDPOpt/bin/simpleFoam"
[2] #8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #9
[cfdworkstation:12006] *** Process received signal ***
[cfdworkstation:12006] Signal: Floating point exception (8)
[cfdworkstation:12006] Signal code:  (-6)
[cfdworkstation:12006] Failing at address: 0x3e800002ee6
[cfdworkstation:12006] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f2e1997fd80]
[cfdworkstation:12006] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f2e1997fd05]
[cfdworkstation:12006] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x33d80) [0x7f2e1997fd80]
[cfdworkstation:12006] [ 3] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam3magINS_10SymmTensorIdEENS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT0_T1_EEEERKNS5_INS6_IT_S7_S8_EEEE+0x169) [0x7f2e1c891929]
[cfdworkstation:12006] [ 4] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam14incompressible9RASModels9kOmegaSSTC2ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS3_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelERKNS_4wordESK_+0xdab) [0x7f2e1c88912b]
[cfdworkstation:12006] [ 5] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam14incompressible8RASModel31adddictionaryConstructorToTableINS0_9RASModels9kOmegaSSTEE3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS6_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelERKNS_4wordE+0x58) [0x7f2e1c894608]
[cfdworkstation:12006] [ 6] /opt/openfoam210/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam14incompressible8RASModel3NewERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERNS_14transportModelERKNS_4wordE+0x3f9) [0x7f2e1c80dc19]
[cfdworkstation:12006] [ 7] simpleFoam() [0x419d49]
[cfdworkstation:12006] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xff) [0x7f2e1996aeff]
[cfdworkstation:12006] [ 9] simpleFoam() [0x416d09]
[cfdworkstation:12006] *** End of error message ***
mpirun noticed that process rank 2 with PID 12006 on node cfdworkstation exited on signal 8 (Floating point exception).
Verfblikje is offline   Reply With Quote
Old   February 27, 2012, 05:15
Nick
No one has any idea?
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 16:34
simpleFoam ddt Euler ? Mo-ITB OpenFOAM Running, Solving & CFD 2 June 12, 2010 13:36
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 03:08
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 09:42
