fvSchemes in bubbleFoam
Old   February 23, 2012, 17:37
Default fvSchemes in bubbleFoam
Jeong Kim
enoch is on a distinguished road
I was trying to modify bubbleFoam before going to more complex problems.
When I looked at "fvSchmes" located in the systmes foler of bubbleFoam,
I was not sure about it. Here are two questions.
Q1. I think I have to consider below shemes for Rca and Rcb, respectively, but why are they not included in the schemes?
div(phiRa, Ua) Gauss limitedLinearV 1; //why is it not included?
div(phiRb, Ub) Gauss limitedLinearV 1; //why is it not included?
div(phir, alpha) Gauss limitedLinear01 1; //Need for alpha continuity equation?
Q2. I think I could use div(Rca) and div(Rcb), but it could not work. The solver looked for div(-nuEffa*grad(Ua).T()) and div(-nuEffb*grad(Ub).T()).
In UEqns.H,
volTensorField Rca = -nuEffa*(fvc::grad(Ua)().T());
Rca = Rca + ...;
I would really appreciate that if you could give some commenst to me.
enoch is offline   Reply With Quote
Old   February 24, 2012, 02:51
Alberto Passalacqua
The piece of code in the equation says:
fvm::div(phiRa, Ua, "div(phia,Ua)")
so the scheme specified for div(phia,Ua) is used for this term too.
The code for the alphaEqn contains
fvm::div(-fvc::flux(-phir, beta, scheme), alpha, scheme)
where
word scheme("div(phi,alpha)");
So, it is sufficient to specify a scheme for div(phi,alpha). This is done for consistency of the discretisation.
In UEqns.H,
Rca = Rca + ...;
If you look at the tutorial case, these schemes are specified:
    div((-nuEffa*T(grad(Ua)))) Gauss linear;
    div((-nuEffb*T(grad(Ub)))) Gauss linear;
However, in general, if you define a field, its string name is used to look up in the dictionaries, and not its variable name. For example, if you define
volScalarField a = -b*c;
the code won't look for "a", but for an expression derived from the calculation. If you want to fix this problem, simply assign a name to your field:
volScalarField a
      "a",
      -b*c
and the code will look for "a" in the dictionaries, instead than for the, usually complicated, expression.
Best,
Alberto Passalacqua
interFoam / bubbleFoam to simulate an aerated tank Meratb OpenFOAM Running, Solving & CFD 3 November 6, 2020 11:45
fvschemes and fvsolutions in MRFSimpleFoam renyun0511 OpenFOAM Running, Solving & CFD 23 August 3, 2011 04:07
a question about bubbleFoam xck1986 OpenFOAM 1 June 21, 2011 09:30
Inputs for bubbleFoam rans2009 OpenFOAM 0 October 8, 2009 07:59
bubbleFoam rans2009 OpenFOAM 3 October 5, 2009 04:28
