MRFSimpleFoam generates stack overflow
Old   February 28, 2012, 06:19
Default MRFSimpleFoam generates stack overflow
Daniel Witte
danny123 is on a distinguished road
I have problem on MRFSimpleFoam. The calculation starts just fine. After some iterations, it generates the following error:
Time = 0.435
smoothSolver: Solving for Ux, Initial residual = 0.000747915, Final residual = 8.79793e-06, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.000770294, Final residual = 9.06574e-06, No Iterations 4
smoothSolver: Solving for Uz, Initial residual = 0.00062951, Final residual = 7.33717e-06, No Iterations 4
GAMG: Solving for p, Initial residual = 0.00230964, Final residual = 9.97597e-05, No Iterations 3
time step continuity errors : sum local = 2.99323e-09, global = -9.6741e-22, cumulative = 8.70791e-20
ExecutionTime = 797.74 s ClockTime = 798 s
Time = 0.4375
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigSegv::sigHandler(int) in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::tmp<Foam::Field<Foam:uterProduct<Foam::Vec tor<double>, Foam::Vector<double> >::type> > Foam:perator*<Foam::Vector<double>, Foam::Vector<double> >(Foam::UList<Foam::Vector<double> > const&, Foam::tmp<Foam::Field<Foam::Vector<double> > > const&) in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4 Foam::fv::gaussGrad<Foam::Vector<double> >::correctBoundaryConditions(Foam::GeometricField< Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5 Foam::fv::gaussGrad<Foam::Vector<double> >::calcGrad(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6 Foam::fv::gradScheme<Foam::Vector<double> >::grad(Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) const in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#7 Foam::tmp<Foam::GeometricField<Foam:uterProduct< Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#8 Foam::tmp<Foam::GeometricField<Foam:uterProduct< Foam::Vector<double>, Foam::Vector<double> >::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<Foam::Vector<double> >(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#9 Foam::incompressible::RASModels::laminar::divDevRe ff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
in "/home/dw/OpenFOAM/OpenFOAM-2.0.1/platforms/linux64GccDPOpt/bin/MRFSimpleFoam"
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
Speicherzugriffsfehler
It seems to me that error appears when OpenFoam is about to write the 0.45 time folder. The error seems reproducible. The total time is set to 2 s. My system is Ubuntu 11.4 on Intel I7 980 (6 dual core).
Is there anybody who can help?
Thanks,
Daniel
danny123 is offline   Reply With Quote
Old   March 7, 2012, 10:43
Default get around
Daniel Witte
It seems that nobody is really interested in this. Meanwhile I found a workaround. I ran the case in parallel using my 12 CPU that I have. This worked fine. Recomposing the case brought up a minor error in the 0.5 directory U field. One caracter was wrong (removed it).
So, it seems that running parallel is more stable.
error, mrfsimplefoam, printstack
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
Stack Overflow imrannazir Main CFD Forum 7 July 9, 2011 01:53
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Stack overflow MING Main CFD Forum 10 October 20, 2004 14:02
Stack frame size, Origin 2000, fortran, a question. Sergei Chernyshenko Main CFD Forum 4 February 22, 1999 14:24
