Error, running a modified version of twoPhaseEulerFoam |
March 11, 2012, 16:17 |
Alexander
Rep Power: 14 |
Hi
I am running a modified version of the solver twoPhaseEulerFoam. The problem is that i can not understand how to get around the error message i get. I understand at some level that there are some dimensions that are wrong somewhere. however, it seems like the error is in "dimensionSet" at line 142, and i do not know where that file is. I am trying to simulate a stratified air/water pipe. I have put uniform conditions in the "0"folder. To achieve that, i took away the default inletOutlet boundary condition in the "0" folder. I want this eventually to be a laminar case (100 m pipe-length). The simulation and the error message i get is the following: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-131caa989cd3 Exec : twoPhaseEulerFoam Date : Mar 11 2012 Time : 21:40:16 Host : user-VirtualBox PID : 8509 Case : /home/user/OpenFOAM/user-1.7.1/run/stratPipe01 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phia Calculating face flux field phib Reading field alpha Reading field p Reading field k Reading field epsilon Calculating field nutb Calculating field nuEffa Calculating field nuEffb Calculating field DDtUa and DDtUb Calculating field g.h Selecting dragModel for phase a: SchillerNaumann Selecting dragModel for phase b: SchillerNaumann dragPhase is blended Selecting viscosityModel Syamlal Selecting conductivityModel HrenyaSinclair Selecting radialModel Gidaspow Selecting granularPressureModel Lun Selecting frictionalStressModel JohnsonJackson Courant Number mean: 1 max: 2 Starting time loop Courant Number mean: 1 max: 2 Max Ur Courant Number = 0 Reading/calculating field UaMean Reading/calculating field UbMean Reading/calculating field alphaMean Reading/calculating field pMean fieldAverage: starting averaging at time 0 Time = 1 DILUPBiCG: Solving for alpha, Initial residual = 0.999993, Final residual = 1.50555e-16, No Iterations 1 Dispersed phase volume fraction = 0.5 Min(alpha) = 0.5 Max(alpha) = 0.5 DILUPBiCG: Solving for alpha, Initial residual = 0.326787, Final residual = 5.03032e-17, No Iterations 1 Dispersed phase volume fraction = 0.5 Min(alpha) = 0.5 Max(alpha) = 0.5 --> FOAM FATAL ERROR: Different dimensions for = dimensions : [1 -3 -1 0 0 0 0] = [0 0 0 0 0 0 0] From function dimensionSet:perator=(const dimensionSet& ds) const in file dimensionSet/dimensionSet.C at line 142. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::dimensionSet:perator=(Foam::dimensionSet const&) const in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #3 in "/home/user/OpenFOAM/user-1.7.1/applications/bin/linux64GccDPOpt/twoPhaseEulerFoam" #4 __libc_start_main in "/lib/libc.so.6" #5 in "/home/user/OpenFOAM/user-1.7.1/applications/bin/linux64GccDPOpt/twoPhaseEulerFoam" Aborted I am not very experiensed in interpreting theese OpenFOAM error messages, so of course any help would be deeply appreciated. Alex |
dsmcFoam modified version download | Marta | OpenFOAM | 27 | July 1, 2023 10:23 |
compiling error(s) in a modified twoPhaseEulerFoam solver | foamer | OpenFOAM | 14 | June 20, 2014 08:51 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
[OpenFOAM] Problem with paraFoam on a linux-64 bit | bunni | ParaView | 4 | April 14, 2010 20:55 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
