GGI Dynamic RPM: Speed question
Old   March 22, 2012, 12:21
Default GGI Dynamic RPM: Speed question
Robert
lordvon is on a distinguished road
I am preparing a case where OpenFOAM is called from a script to run one iteration at a time. This is to extract forces and moments each timestep to calculate a new RPM and rewriting dynamicMeshDict.
Can someone elaborate on the runtime of this program, stopping and starting OpenFOAM every iteration? How much slower would it be than if I could better integrate the RPM change in the OpenFOAM software?
lordvon is offline   Reply With Quote
Old   March 23, 2012, 07:39
Gabriele
protarius is on a distinguished road
Actually I'm interested in this problem too.
In the simple case of a turbine rotating around a fixed axis, I ask if it is possible to use a ODE solver for the equation
I \dot{\omega} = M
where \omega is the angular velocity (of the turbine, hence of the GGI), I is the fixed moment of inertia and M is the torque (referred to the rotation axis) that comes from "forces" library.
The angular velocity in the dynamicMeshDict should be "linked" to the above equation.
I'm new in OF, so I don't know if it is correct and possible.
Regards
protarius is offline   Reply With Quote
Old   March 23, 2012, 11:32
Robert
Its definitely possible. See here: http://www.youtube.com/watch?v=wjr7NUe5hfg
I was just going to use a form of what you had stated:
(torque) = (rotational inertia) * (angular acceleration)
take (angular acceleration) = (change in angular velocity) / (time step)
then (change in angular velocity) = (time step) * (torque from forces output) / (rotational inertia)
Old   March 23, 2012, 15:37
Gabriele
Thanks.
I think this is the point:
Can I get a reliable result applying only this rough formula? Which is the "right" time step?
I was thinking about applying also some ODE solver to get a better control of the time step, but I don't know if it is necessary.
Regards
Question about Dynamic Mesh Kosum FLUENT 3 December 25, 2008 10:00
A question about dynamic overset grids JXIA Main CFD Forum 4 January 10, 2008 03:50
question about dynamic meshes zhhwoo FLUENT 0 August 2, 2006 22:36
A Question on the Dynamic procedure in LES dragon Main CFD Forum 1 April 28, 2005 15:11
A question about the dynamic mesh UDF Tango FLUENT 1 November 27, 2003 02:56
