BC -> k e simpleFoam
Like Tree4Likes
Old   March 23, 2012, 06:47
Default BC -> k e simpleFoam
Klio
klio is on a distinguished road
Hello!
I tried to simulate a simple airflow with the kEpsilon model, solver simpleFoam. a totalPressureInlet with 0.44 pa is given. Velocity has to be calculated. The residuals and the continuity looks good but the velocity much to small about 1e-06. the Solution should be about 0.35 m/s.
BC:
U:
internalField uniform (0 0 0);
outlet: type zeroGradient;
inlet: type pressureInletVelocity;
value uniform (0 0 0);
wall: type fixedValue;
p:
inlet: type totalPressure;
p0 uniform 0.44;
value uniform 0.44;
gamma 1;
wall: type zeroGradient
epsilon:
internalField 0.02247;
inlet: type turbulentIntensityKineticEnergyInlet;
intensity 0.001;
value uniform 0.02247;
wall: type epsilonWallFunction;
k
inlet: type turbulentMixingLengthDissipationRateInlet;
mixingLength 0.01;
value uniform 1.356e-03;
wall: type kqRWallFunction;
Has anyone a hint for me ?
klio is offline   Reply With Quote
Old   March 23, 2012, 08:32
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I'm guessing it is an issue with your p and U boundary conditions. Neither of them actually drive a flow. You'd need something like a fixed value U or a fixed pressure gradient to get some momentum into the domain.
kmooney is offline   Reply With Quote
Old   March 27, 2012, 03:53
Klio
Hi!
Thanks for your quick reply!
With fixedGradent instead of fixedValue in my pressure inlet BC i got a flow in my flow simulation .
Old   March 28, 2012, 02:37
Klio
Ok but now i got the problem that the pressure decreases at the inlet. i thought fixed Gradient is NOT variable.
Do you have an idea what goes wrong there?
Old   March 28, 2012, 12:50
soonic's Avatar
Peter
soonic is on a distinguished road
Send a message via ICQ to soonic Send a message via AIM to soonic Send a message via Skype™ to soonic
Perhaps nothing is wrong. You fixed the gradient, not the value.
soonic is offline   Reply With Quote
Old   March 29, 2012, 06:56
Klio
hmmm... Thanks!
But I have the Problem that I just know the fix pressure value at the inlet and if I only fix the Value there, there is nothing which drives my Flow.
so should I fix the value and the gradient at the inlet and how does it works ?
Old   March 29, 2012, 08:47
soonic's Avatar
Peter
what is the dimension of the p variable you have prediscribed ?
check if it is not p/rho. And you have maybe correct solution for the wrong task.
Old   March 29, 2012, 08:57
Klio
yes it is p/rho!
My pressure is about 0.5 pa, rho is 1.225 so my PressureValue is about 0.44
an the solution is about 2000 times smaller!
I also tried to set initial conditions with potentialFoam but either my velocities are much to small or much to high!
Old   March 29, 2012, 09:16
Klio
I think I can't really imagine how the BC at inlet and outlet of U and P should be set correctly.
When I take a look at the examples I can only find BC where the velocity is known. Not so in my case!
Old   March 29, 2012, 09:43
soonic's Avatar
Peter
try attached case with simpleFoam. It seems fine with your values on D=1cm pipe.
(it is based on case_pipe_viscous_heating for mySimpleFoam solver found on that forum)
edit: it is only laminar case.
Old   March 29, 2012, 09:49
Klio
Ok I'll try it thank you very much. Hope that even works in k e model
Old   March 29, 2012, 11:33
soonic's Avatar
Peter
yes, it do. Tried with 10Pa on inlet to have Re in turbulent zone.
Old   March 30, 2012, 02:24
Klio
Thank you very much for this nice example. I took same BC for k-e-Model and it didn't worked!
Old   March 30, 2012, 07:41
Klio
Hi at all!
now the Laminar model works!
But if I take the same BC as in the laminar model for the kE-Modell it doesn't work!
My BC are:
k & epsilon
interiorField: 1
pressure_inlet: 1
pressure_outlet: 1
wall: WllFunktion 1
p
interiorField: 0
pressure_inlet: 0.44
pressure_outlet: 0
wall: zeroGradient
U
interiorField: (0 0 0)
pressure_inlet: zeroGradient
pressure_outlet: zeroGradient
wall: (0 0 0)
Can anyone help me?
Old   April 2, 2012, 07:24
soonic's Avatar
Peter
what is not working? descrbie more.
Is your Re in turbulent zone ? Try initialize the case with higher eps values and add approximate/correct values for k and eps at your BCs.
the test case with values of one "does not work" too. Correct values will make it.
Old   April 3, 2012, 01:52
Klio
Thinks for your help!
In my case i have to compare fluent with openFoam! So i got a simulation from my college with given BC. And to compare it correctly I have do set the same initial condition as he did. Which is k & epsilon is 1 the pressure is 0.5 (in my case 0.44 because of dimensions) and velocity is not known. so its not possible to change the values.
If I set the BC like shown before the simulation crashes with errors! I think because of the bounding variables (up to inf) -> velocities higher than 1e+20. I also tried to set BC of k eps at the walls to zeroGradient it also didn't work. Its also diverging
Old   April 3, 2012, 03:22
soonic's Avatar
Peter
I tryed to set correct values for pressure to have turbulent flow and set calculated values for k and eps and there is the case again.
I still do not know, how big is your pipe. I just bet, that correct values for k and epsilon are thousand times smaller than one.
Old   April 3, 2012, 04:47
Oluwalogbon Akinnola
lobstar is on a distinguished road
Hi kilo, I'm having the exact same problem as you. I'm also trying to do a comparison between fluent and openfoam using a turbulent flow. I've also tried using simplefoam and the k-e model. I haven't been able to get the simulation to work using a set pressure drop and having velocity calculated, but used my results from the fluent to set the boundary conditions and I'm also getting velocities of 1e20. I haven't been able to get soonic's suggestions to work for me. Have you had any luck?
lobstar is offline   Reply With Quote
Old   April 3, 2012, 09:56
Klio
hi!
@soonic:
hmm ... my Model is a cube with a 0.006 m thick pipe (0.06 m long ) at the inlet and same at the outlet.
I also have calculated the k and epsilon for the model but it must work somehow with the same input parameter a fluent gets. ive tried now :
k & epsilon
interiorField: 0
pressure_inlet: 1
pressure_outlet: 1
wall: zeroGradient
p
interiorField: 0
pressure_outlet: 0
wall: zeroGradient
U
wall: (0 0 0)
-----> IT WAS MUCH BETTER! but now the velocity is to small!! 0.002 instead of 0.35
@lobstar:
no i had no luck!!!
but i found out that k & epsilon & nut File should have same type of wall BC! and don't let OpenFoam generate your nut file or others automatically!
if you found out anything please tell me - i'll do the same!
you should also set the internal Field of k an epsilon 0, because i fond out that fluent also does so! and if you don't know what fluent does you can tell fluent to write out bc and then you get an acci file (terrible to read but lots information in it!)
lobstar likes this.
Old   April 3, 2012, 10:15
kmooney's Avatar
Kyle Mooney
You might want to take a second swing at your k & E boundary/internal conditions. I'm not too familiar with setting up these kinds of models but those values look like they might be pretty off after looking at this setup: [tutorials/incompressible/simpleFoam/pitzDaily]. Perhaps try reading up on the models' best practices or looking at some of the other tutorials with k&E turbulence modeling already set up.
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 06:27
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 09:07
simpleFoam crash -> How to solve tH3f0rC3 OpenFOAM 4 May 12, 2011 07:07
1.7.x -> buoyantPimpleFoam -> hRhoThermo -> incompressible and icoPoly3ThermoPhysics? will.logie OpenFOAM 0 December 16, 2010 07:08
Naca0012 k-e mpirun gives fpe whereas simpleFoam not Pierpaolo OpenFOAM 1 May 8, 2010 03:08
