openFoam 2.1.x: creating AMI patches from a cylinder.
Old   March 26, 2012, 03:11
Default openFoam 2.1.x: creating AMI patches from a cylinder.
Elh. A2. BAH
ebah6 is on a distinguished road
Dear all,
I am inspiring my self from the pimpleDyMFoam/propeller tutorial to run a case.
But when I create the AMI from an .obj cylinder, the surface is all messed up.
Attached is my picture from paraFoam.
Can some help me out with this.
Thank you all.
ebah6 is offline   Reply With Quote
Old   March 26, 2012, 07:19
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
We really need some more info.
How is the mesh created?
It looks like SHM, and if that is the case it looks like either your background mesh is too coarse or the refinement level on the AMI is too low.
On another note to improve stability during simulation it can be a good idea to keep the same refinementlevel on the ami/ggi's to avoid concave faces.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   March 26, 2012, 07:44
Elh. A2. BAH
Thank you sir,
I did a lot of "gymnastic" to get the .obj file.
1) create mesh with Pointwise and export it as .cas (i.e fluent)
2) with ANSYS ICEM-CFD I converted it to .stl
3) the use blender to get the .obj extension.
I made a trial by using the .stl file and got the picture attached.
Regarding your suggestions refining the outer box and/or the AMI, I think just need to refine my hex box in the blockMeshDict. How about the the AMI refinement? where should do this?
Please, allow that I ask related question.
a) how do I go and determine the value of startFace in system/changeDictionary?
As of now, I have to run it twice: first I let it crash and give a number that I plug back in and re-run.
b) another issue I have being struggling all along is the inlet and outlet pressure and velocity boundary conditions. could suggest a combination?
My apologies if these questions are too basic, but I am newbie.
Old   March 26, 2012, 07:59
linnemann's Avatar
Niels Nielsen
From the propeller tutorial.
         innerCylinderSmall
            level       (4 4); // this is the refinement
            cellZone    innerCylinderSmall;
            faceZone    innerCylinderSmall;
            cellZoneInside  inside;
I can see you are making a VAWT simulation.
Here is a case I made you can use as inspiration with setup etc.
3D structured VAWT case
This is made using 1.6-ext but its a matter of changing the ggi's to ami's.
PS. VAWT are horrible energy producing devices, don't waste your time on them, other than pure interest.
Try to find a company that's willing to share real world produced energy data.
Linnemann
Old   March 26, 2012, 13:27
Elh. A2. BAH
Thank you very much sir.
Old   March 26, 2012, 18:06
Elh. A2. BAH
Hello again,
I have been using the same level of refinement as in the propeller tutorial. And I refined my outer block by 6 times but these right angle features still persist.
May be it is that my .stl geometriy is not good enough. Could you tell me what you used to create you geometries?
Also, if you have lead on the BC setup as I mentioned earlier.
Thank you for your patience.
Regards.
OpenFOAM 2.1.x Windows Patch Released gocarts OpenFOAM Announcements from Other Sources 0 January 18, 2012 14:56
[mesh manipulation] createPatch / cyclicGgi / OpenFoam 1.5-dev OFU OpenFOAM Meshing & Mesh Conversion 0 June 16, 2010 04:36
OpenFOAM 1.6 CreatePatch Problem TarifaPirata OpenFOAM Bugs 1 September 10, 2009 04:35
Creating cylinder in STAR-CD Sachin Siemens 2 March 6, 2008 02:53
Creating patches usinf CFX 4.4 Meshbuild Kev CFX 0 August 30, 2004 19:39
