simpleFoam /water in pipes/ how to obtain and tune the solution?
Old   March 29, 2012, 10:40
Default simpleFoam /water in pipes/ how to obtain and tune the solution?
soonic's Avatar
Peter
soonic is on a distinguished road
Send a message via ICQ to soonic Send a message via AIM to soonic Send a message via Skype™ to soonic
Dont know how to hide or delete this for now, but i found mismatched BC. But maybe I will need help later. Thanks for visit.
I am solving water flowing in pipe in steadyState by simpleFoam. I have Re~20000. Velocities 1÷2m/s. I am unable to converge with my case. I did a comparison of case with laminar vs. k-eps regime, and tetra vs. polyhedral mesh (produced by polyDualMesh from that tets). Could you help me to tune up fvSchemes and fv Solution, please ? Or is it grid or BC related issue ?
I have read and tried several ideas written on the forum but no big success. I also divided the case in solving bended knee only, T-juction only. They have converged, but now the solution blows up e.g. on k and epsilon bounding and time step continuity error at some point of computation. I would like to compute temperature fields later on, but I am unable to solve flow for now.
my case:
boundaries are like: green inlet (hot water); red outlet (hot water); red inlet(cold water); blue outlet(cold water). Hot outlet and cold inlet is the same diameter and mass flow.
Files from system folder are attached. CheckMesh for both meshes as well. BCs are in the end of post. Now I will show resiaduals. Maybe somebody knows what happens there.
Thank you
http://soonic.cesnak.org/cfd/lam_pol...b_polyTurb.png
p
internalField   uniform 0;
boundaryField
    inh
         type            zeroGradient;
    inc
        type            zeroGradient;
    outh
    type            fixedValue;
        value           uniform 0;
    outc
         type            zeroGradient;
    stena
        type            zeroGradient;
U
internalField   uniform (0 0 0 );
boundaryField
    inh
        type            fixedValue;
        value           uniform (0.504 0 0); //Value is half scaled for laminar case
    outh
        type            fixedValue;
        value           uniform (0 1.7654 0); //Value is half scaled for laminar case
    inc
        type            fixedValue;
        value           uniform (0 -1.7654 0); //Value is half scaled for laminar case
    outc
        type            zeroGradient;
    stena
        type            fixedValue;
        value           uniform (0 0 0);
k
internalField   uniform 0.004;
boundaryField
    inh
        type            turbulentIntensityKineticEnergyInlet;
        intensity       0.04726;
        U               U;
        phi             phi;
        value           uniform 0.000852;
    outh
        intensity       0.04229;
        U               U;
        phi             phi;
        value           uniform 0.00836;
    inc
        intensity       0.04229;
        U               U;
        phi             phi;
    outc
        type            zeroGradient;
    stena
        type            kqRWallFunction;
        value           uniform 0.001;
epsilon
internalField   uniform 100;
boundaryField
    inh
        type            turbulentMixingLengthDissipationRateInlet;
        mixingLength    0.034678;
        phi             phi;
        k               k;
        value           uniform 0.0001179;
    outh
        mixingLength    0.02407;
        phi             phi;
        k               k;
        value           uniform 0.0052217;
    inc
        phi             phi;
        k               k;
    outc
        type            zeroGradient;
    stena
        type            epsilonWallFunction;
soonic is offline   Reply With Quote
