Can't run in parallel
Old   March 29, 2012, 21:03
Default Can't run in parallel
Jason Eason
JulytoNovember is on a distinguished road
I'm using OpenFOAM-1.6-ext when I try to run my case in parallel I get this error.
PHP Code:
eason@eason-laptop:~$ cd Desktop/1
 eason
@eason-laptop:~/Desktop/1foamJob --p pimpleDyMFoam
 Parallel processing using OPENMPI with 2 processors
 Executing
mpirun -np 2 /home/eason/OpenFOAM/OpenFOAM-1.6-ext/bin/foamExec pimpleDyMFoam -parallel tee log
/home/eason/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc308: [[: not found
 export
21: -pthreadbad variable name
 export
mpirun noticed that the job abortedbut has no info as to the process
 that caused that situation
The case decomposed and my it will run on a single processor. I've tried everything I've read on this site. Seems like foamJob or foamExec is not finding the bashrc file for OpenFOAM-1.6-ext. Any ideas on what is wrong or how can I fix it?
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   March 30, 2012, 08:14
Joe
jferrari is on a distinguished road
I'm not sure how foamJob works, but when I do parallel runs I use the line:
mpirun -np 6 pimpleFoam -parallel > log &
They only thing I don't see in your code is the -parallel option. Try using the command above instead of foamJob and see if that works.
jferrari is offline   Reply With Quote
Old   March 31, 2012, 09:28
Jason Eason
Thank you for your help, its works I appreciate the help. Now I can use all 8 cores.
parallel foamjob foamexec
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 14:43
Unable to run OF in parallel on a multiple-node cluster quartzian OpenFOAM 3 November 24, 2009 13:37
serial run fine, but parallel run diverged phsieh2005 OpenFOAM Running, Solving & CFD 2 October 6, 2009 08:33
Parallel run diverges, serial does not SammyB OpenFOAM Running, Solving & CFD 1 May 10, 2009 03:28
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 06:33
