Ivan
Rep Power: 5 ![]() |
Hello everyone,
I'm trying to validate a well-known case, turbulent flow over NACA0012. Information of the validation ca be found here: https://turbmodels.larc.nasa.gov/naca0012_val.html I simulated properly the case with the version of OpenFoam v2006, obtaining succefull results. I can say that I validated the case because I got accuracy values for Cl and Cd for differents angles of attacks (0º, 3º, 6º, 9º, 12º and 15º). I did that with two different turbulence models (RAS-Spalart Allmaras and RAS-KwSST) using the solver simpleFoam. The problem is the following one. I tried to run the SAME case with a version of OpenFoam installed by means of Docker. (IN THE SAME LAPTOP). Both are supposed to be the same version but the results are differents (Relative error 30 %) and it isn't related with the time of convergence. Has anyone suspect where can be the problem? If someone is interested in look over the code, the case for AoA 3 degrees is here: https://drive.google.com/file/d/1p2P...ew?usp=sharing The case is ready to run with simpleFoam. Thank for your time. |
Ivan
Thank you very much for the reply.
They are the same file. (Copy and paste) That’s the crazy thing. |
Ivan
I'm sure it is related with the solver.
Where I can find the defualt values that OF uses? I'm searching in the libraries, but I didn't find anything which could fix it |
Ansys Installation on Docker Container | mohsen.shiea | ANSYS | 11 | March 14, 2024 11:18 |
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker | u2berggeist | OpenFOAM Installation | 1 | July 10, 2018 02:58 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 10:22 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
