Nonsymmetric result from symmetric flow and geometry? |
August 27, 2022, 14:24 |
Hello all,
I have a fairly good experience in commercial CFD solvers (Fluent and the likes) but wanted to try OPENFOAM. I started with a simple geometry and flow to get used to the openfoam file structure but received an unexpected result. The flow seems to stick to one side of the nozzle after a certain number iterations. I presumed it was due to a numerical error that accumulated over time, but running it several times produced the same result. This does not seem to happen when the restricted section in the middle is wider. I run the simulation using icoFoam (following blockMesh) P.S. only one cell is in the z-direction. fvSchemes and fvSolution are directly from icoFoam tutorials. Files and velocity field screenshot are attached below. Any ideas would be appreciated. Thank you. |
September 8, 2022, 03:10 |
Rep Power: 5 |
Hey
I am not 100% sure about this, but I simulated venturi nozzles a while back and had similar behaviors. From what I can remember, which is not a lot, at certain reynolds number (or some other adimensional number), the flow is expected to deviate like your picture. I guess that if you tried in a transient simulation, the flow might oscillate and not stick to only one side. (I might be totally wrong! Check some scientific papers, I know there are some talking about this) |
An error occurs.'Increase the file catalog size. ' | dhehdxhdaus | CFX | 3 | April 10, 2022 20:13 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Initialize flow from different geometry | B.Axel | FLUENT | 2 | January 24, 2018 13:15 |
Laminar pipe flow using 2D axis symmetric geometry | nandiganavishal | OpenFOAM Running, Solving & CFD | 4 | April 1, 2013 00:48 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
