Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
PyFoam compares fields from the test case for 2 solver versions
Old   September 13, 2023, 03:33
Default PyFoam compares fields from the test case for 2 solver versions
Alexander
starab is on a distinguished road
Dear All,
I was not able to find such discussion in the forum.
We intend to adjust the solver and verify it against generic cases, say, by differences in velocity field.
I am sure that PyFoam is able to do it, but it comes with too short examples and manuals.
The example runPitzDailyBasic.py has in postRun-function comparison between data and reference data. But I do not understand, how this data extracted from the case.
Should I add velocity field from the specific time step to runInfo of CTestRun object? How?
Or should I save the velocity field without PyFoam and use it in comparison afterwards?
Thank you
starab is offline   Reply With Quote
Old   September 22, 2023, 05:47
Alexander
Moving ahead but stuck with SamplePlot parsing sets (which drives comparison method).
My sets look like (in OF10)
sets(
data(
type lineUniform;
axis distance;
surfaces ();
fields ( p );
as result I see data.xy ascii-files per timestep with 2 columns: distance and p.
The command
pyFoamSamplePlot --dir=postProcessing/sample --info
returns list with steps, list with a single line, and unfortunately empty list of fields.
Why SamplePlot does not see the samples?
Old   September 22, 2023, 05:59
Alexander
sets(
data(
type lineUniform;
axis distance;
surfaces ();
fields ( p );
The command
CPUs vs GPUs for CFD? hami11 Hardware 21 May 14, 2024 08:00
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 08:27
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
2D test case validation in a 3D solver AshwaniAssam Main CFD Forum 4 October 1, 2015 07:51
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
