PyFoam compares fields from the test case for 2 solver versions |
September 13, 2023, 03:33 |
Alexander
Rep Power: 15 |
Dear All,
I was not able to find such discussion in the forum. We intend to adjust the solver and verify it against generic cases, say, by differences in velocity field. I am sure that PyFoam is able to do it, but it comes with too short examples and manuals. The example runPitzDailyBasic.py has in postRun-function comparison between data and reference data. But I do not understand, how this data extracted from the case. Should I add velocity field from the specific time step to runInfo of CTestRun object? How? Or should I save the velocity field without PyFoam and use it in comparison afterwards? Thank you |
September 22, 2023, 05:47 |
Alexander
Rep Power: 15 |
Moving ahead but stuck with SamplePlot parsing sets (which drives comparison method).
My sets look like (in OF10) sets( data( type lineUniform; axis distance; ) ); surfaces (); fields ( p ); as result I see data.xy ascii-files per timestep with 2 columns: distance and p. The command pyFoamSamplePlot --dir=postProcessing/sample --info returns list with steps, list with a single line, and unfortunately empty list of fields. Why SamplePlot does not see the samples? |
September 22, 2023, 05:59 |
Alexander
Rep Power: 15 |
CPUs vs GPUs for CFD? | hami11 | Hardware | 21 | May 14, 2024 08:00 |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
2D test case validation in a 3D solver | AshwaniAssam | Main CFD Forum | 4 | October 1, 2015 07:51 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
