effect of nonlinear terms
Old   April 23, 2012, 06:15
Default effect of nonlinear terms
Farshad
Farshad_Noravesh is on a distinguished road
I have a problem when i add a nonlinear term(quadratic term) inside my source term and openfoam gets error. what is the best config for fvsolution and fvschemes for these nonlinear effects?
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.10082e-06, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.23009e-06, No Iterations 1
DILUPBiCG: Solving for c, Initial residual = 1, Final residual = 2.55268e-06, No Iterations 1
min(c) = 0
DILUPBiCG: Solving for sigma, Initial residual = 1, Final residual = 1.84628e-06, No Iterations 3
max(sigma) = 1
DILUPBiCG: Solving for hu, Initial residual = 1.61405e-05, Final residual = 5.77265e-11, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.999974, Final residual = 2.25102e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 9.19628e-07, No Iterations 32
time step continuity errors : sum local = 6.16706e-14, global = -5.94702e-15, cumulative = -5.94702e-15
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.28008e-06, No Iterations 1
DILUPBiCG: Solving for Ux, Initial residual = 0.196429, Final residual = 1.12715e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.111858, Final residual = 3.43147e-08, No Iterations 1
DILUPBiCG: Solving for c, Initial residual = 0.283645, Final residual = 4.53729e-07, No Iterations 1
min(c) = 0
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/farshad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/farshad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 in "/lib64/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/farshad/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/farshad/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/fsd1"
#6 __libc_start_main in "/lib64/libc.so.6"
at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
farshad@linux-0dde:~/OpenFOAM/farshad-1.7.1/run/flamesurfacedensity1>
Kind Regards,
Farshad
Farshad_Noravesh is offline   Reply With Quote
Old   April 24, 2012, 11:42
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Farshad,
Are you adding an implicit of explicit nonlinear term? After all, the linear system solvers only solve the linear system and can't solve nonlinear implicit terms. You will have to "linearize" your nonlinear term if you want it as an implicit term.
More info is helpful.
Dan
chegdan is offline   Reply With Quote
Old   April 24, 2012, 13:41
Default explicit nonlinear term
Farshad
Dear Chegdan,
Thank you very much for your post. I need to add an explicit nonlinear term to the end of flame surface density model developed by Prof.Hawkes and Prof.Cant.
Is it possible to solve it without linearizing the pde?
Kind Regards,
Farshad
Using source terms jsm Main CFD Forum 4 August 20, 2009 06:44
Question in definition of terms in solve titio OpenFOAM Running, Solving & CFD 0 March 19, 2009 16:02
Could someone suggest simple (nonlinear) solver Bren Main CFD Forum 10 March 7, 2009 06:36
Nonlinear problem with almost no implicit terms rafal OpenFOAM Running, Solving & CFD 4 April 24, 2008 08:11
K-Epsilon model? Brindaban Ghosh Main CFD Forum 2 June 24, 2000 04:22
