Laminar flux
Like Tree1Likes
  • 1 Post By nimasam
Old   April 30, 2012, 05:17
Default Laminar flux
anonymous
libia87 is on a distinguished road
HI!
I have a problem similar like "buoyantBoussinesqSimpleFoam" and I would like to know how to change from turbulent flux to laminar flux because I use this example to simulate my problem.
I do this because i'm new with OpenFOAM and I would like to change the parameters of this tutorial,
Thanks!
libia87 is offline   Reply With Quote
Old   April 30, 2012, 18:16
Nima Samkhaniani
nimasam is on a distinguished road
RASModel        laminar;
lovecraft22 likes this.
nimasam is offline   Reply With Quote
Old   May 1, 2012, 10:24
Bernhard Linseisen
Linse is on a distinguished road
In case the note from nimasam is not explanatory enough (though everything in there is said!), here a bit more in detail:
The files you have to change are both in CASENAME/constant and are named RASProperties and turbulenceProperties.
Within RASProperties you have to set the entry for "RASModel" to something different from "laminar". The different legal options are enumerated in the user guide. You also have to switch "turbulence" to "on".
Within turbulenceProperties you will have to switch to RASModel.
I guess if you want to do a LES-simulation, you should exchange RAS by LES and above explanations are true again... ;-)
Hope that helps!
Linse is offline   Reply With Quote
Old   May 2, 2012, 03:45
anonymous
Hope that helps!
thanks! but in "turbulence" I have to switch to "off" if I want a laminar flux, right??
in the tutorial "BuoyantBoussinesqSimpleFoam" doesn't exist the turbulenceProperties, there are "g", "RASProperties" and "transportProperties"
Old   September 5, 2012, 13:51
Anonymous
Tiffany is on a distinguished road
I am also trying to use the dummy RAS turbulence model for laminar flow. (I am using buoyantBoussinesqPimpleFoam as my solver though.) I was wondering, what theory is OpenFOAM programed to use for this model? I don't know C++, so I'm struggling trying to figure out what the source code is actually doing. I have a link to it here: https://unihub.ru/tools/ofservice/br...inar/laminar.H
Do you guys know what equations/theory OpenFOAM is using to solve here?
Thank you!
Tiffany is offline   Reply With Quote
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
