InterFoam negative alpha
Old   May 18, 2012, 01:49
Default InterFoam negative alpha
Kia
karasa03 is on a distinguished road
Hello everyone I am new to OpenFOAM and hopefully i can explain my problem and have it fixed quickly.
I am using interFOAM to simulate blood flow and saline interaction. I have a catheter in a blood vessel and saline solution is injected into inlet of the catheter and comes out at the tip. I am modeling the blood as a Newtonian fluid and everything is laminar at this point.
When I run the simulation, I get negative min(alpha1) numbers and my Liquid phase volume fraction number is supper small. And when I look at it using paraview, it show the saline alpha turn into blood alpha. The velocity and pressure look right so I do not know why my alpha is not being calculated correctly.
HTML Code:
file:///home/kiwi/Dropbox/Photos/blood_saline_alpha1.png
[IMG]file:///home/kiwi/Dropbox/Photos/blood_saline_alpha1.png[/IMG]
Starting time loop
Courant Number mean: 0 max: 0
Interface Courant Number mean: 0 max: 0
deltaT = 1.2e-09
Time = 1.2e-09
MULES: Solving for alpha1
Liquid phase volume fraction = 0 Min(alpha1) = 0 Max(alpha1) = 1
PIMPLE: iteration 1
GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00733461, No Iterations 11
time step continuity errors : sum local = 7.11934e-12, global = -1.62818e-13, cumulative = -1.62818e-13
GAMG: Solving for p_rgh, Initial residual = 0.0789804, Final residual = 0.000539265, No Iterations 2
time step continuity errors : sum local = 8.32344e-10, global = 7.85013e-12, cumulative = 7.68731e-12
GAMG: Solving for p_rgh, Initial residual = 0.00796039, Final residual = 7.21831e-05, No Iterations 3
time step continuity errors : sum local = 1.20275e-10, global = -1.6724e-12, cumulative = 6.01491e-12
PIMPLE: iteration 2
GAMG: Solving for p_rgh, Initial residual = 0.00233487, Final residual = 1.24411e-05, No Iterations 3
time step continuity errors : sum local = 2.10593e-11, global = -4.16641e-13, cumulative = 5.59827e-12
GAMG: Solving for p_rgh, Initial residual = 0.000394277, Final residual = 3.01518e-06, No Iterations 3
time step continuity errors : sum local = 5.12505e-12, global = -7.12971e-14, cumulative = 5.52697e-12
GAMG: Solving for p_rgh, Initial residual = 9.51221e-05, Final residual = 5.60966e-07, No Iterations 3
time step continuity errors : sum local = 9.54372e-13, global = -1.71028e-14, cumulative = 5.50987e-12
PIMPLE: iteration 3
GAMG: Solving for p_rgh, Initial residual = 2.02063e-05, Final residual = 1.54376e-07, No Iterations 3
time step continuity errors : sum local = 2.62689e-13, global = -3.58164e-15, cumulative = 5.50628e-12
GAMG: Solving for p_rgh, Initial residual = 5.171e-06, Final residual = 7.63952e-08, No Iterations 2
time step continuity errors : sum local = 1.30001e-13, global = -2.05852e-15, cumulative = 5.50423e-12
GAMG: Solving for p_rgh, Initial residual = 1.22273e-06, Final residual = 8.68386e-08, No Iterations 1
time step continuity errors : sum local = 1.47774e-13, global = -2.38579e-15, cumulative = 5.50184e-12
ExecutionTime = 16.13 s ClockTime = 17 s
Courant Number mean: 4.08779e-07 max: 0.000289305
deltaT = 1.44e-09
Time = 2.64e-09
Liquid phase volume fraction = 1.7146e-11 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 3.4292e-11 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 5.1438e-11 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 6.85839e-11 Min(alpha1) = 0 Max(alpha1) = 1
PIMPLE: iteration 1
GAMG: Solving for p_rgh, Initial residual = 0.000570361, Final residual = 4.18279e-06, No Iterations 11
time step continuity errors : sum local = 1.02444e-11, global = 2.32694e-13, cumulative = 5.73453e-12
GAMG: Solving for p_rgh, Initial residual = 0.72832, Final residual = 0.00497247, No Iterations 2
time step continuity errors : sum local = 1.19882e-09, global = -1.12942e-11, cumulative = -5.55967e-12
GAMG: Solving for p_rgh, Initial residual = 0.294599, Final residual = 0.00267426, No Iterations 3
time step continuity errors : sum local = 1.73428e-10, global = 2.39662e-12, cumulative = -3.16304e-12
PIMPLE: iteration 2
GAMG: Solving for p_rgh, Initial residual = 0.437679, Final residual = 0.00233468, No Iterations 3
time step continuity errors : sum local = 3.03803e-11, global = 5.9927e-13, cumulative = -2.56377e-12
GAMG: Solving for p_rgh, Initial residual = 0.412863, Final residual = 0.00316053, No Iterations 3
time step continuity errors : sum local = 7.39308e-12, global = 1.02173e-13, cumulative = -2.4616e-12
GAMG: Solving for p_rgh, Initial residual = 0.164912, Final residual = 0.000973731, No Iterations 3
time step continuity errors : sum local = 1.37731e-12, global = 2.4518e-14, cumulative = -2.43708e-12
PIMPLE: iteration 3
GAMG: Solving for p_rgh, Initial residual = 0.0328144, Final residual = 0.000250931, No Iterations 3
time step continuity errors : sum local = 3.78993e-13, global = 5.10882e-15, cumulative = -2.43197e-12
GAMG: Solving for p_rgh, Initial residual = 0.00806736, Final residual = 5.27134e-05, No Iterations 3
time step continuity errors : sum local = 8.28767e-14, global = 1.08536e-15, cumulative = -2.43089e-12
GAMG: Solving for p_rgh, Initial residual = 0.00199432, Final residual = 6.46556e-08, No Iterations 11
time step continuity errors : sum local = 1.0254e-16, global = -4.80509e-19, cumulative = -2.43089e-12
ExecutionTime = 27.71 s ClockTime = 29 s
Courant Number mean: 4.90274e-07 max: 0.0003464
deltaT = 1.728e-09
Time = 4.368e-09
Liquid phase volume fraction = 8.91177e-11 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 1.09651e-10 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 1.30185e-10 Min(alpha1) = -1.24534e-51 Max(alpha1) = 1
Liquid phase volume fraction = 1.50719e-10 Min(alpha1) = -6.11486e-57 Max(alpha1) = 1
PIMPLE: iteration 1
GAMG: Solving for p_rgh, Initial residual = 0.0533576, Final residual = 0.000324406, No Iterations 4
time step continuity errors : sum local = 7.26737e-13, global = 2.18295e-13, cumulative = -2.21259e-12
GAMG: Solving for p_rgh, Initial residual = 0.0135501, Final residual = 0.000108332, No Iterations 4
time step continuity errors : sum local = 2.39232e-13, global = 1.49219e-14, cumulative = -2.19767e-12
GAMG: Solving for p_rgh, Initial residual = 0.00333453, Final residual = 1.67357e-05, No Iterations 4
time step continuity errors : sum local = 3.66317e-14, global = 1.43155e-15, cumulative = -2.19624e-12
PIMPLE: iteration 2
GAMG: Solving for p_rgh, Initial residual = 0.000663491, Final residual = 3.34355e-06, No Iterations 4
time step continuity errors : sum local = 7.30476e-15, global = 2.96115e-16, cumulative = -2.19594e-12
GAMG: Solving for p_rgh, Initial residual = 0.000135325, Final residual = 6.83283e-07, No Iterations 4
time step continuity errors : sum local = 1.49233e-15, global = 4.4585e-17, cumulative = -2.1959e-12
GAMG: Solving for p_rgh, Initial residual = 3.02876e-05, Final residual = 2.95952e-07, No Iterations 3
time step continuity errors : sum local = 6.46326e-16, global = 2.59109e-17, cumulative = -2.19587e-12
PIMPLE: iteration 3
GAMG: Solving for p_rgh, Initial residual = 6.59564e-06, Final residual = 6.65695e-08, No Iterations 4
time step continuity errors : sum local = 1.45379e-16, global = 2.34212e-18, cumulative = -2.19587e-12
GAMG: Solving for p_rgh, Initial residual = 2.63412e-06, Final residual = 4.01697e-08, No Iterations 2
time step continuity errors : sum local = 8.77245e-17, global = 2.86944e-18, cumulative = -2.19587e-12
GAMG: Solving for p_rgh, Initial residual = 5.98916e-07, Final residual = 4.62872e-08, No Iterations 1
time step continuity errors : sum local = 1.01084e-16, global = 5.20981e-18, cumulative = -2.19586e-12
ExecutionTime = 37.33 s ClockTime = 39 s
karasa03 is offline   Reply With Quote
Old   May 18, 2012, 01:54
Kia
I do not know if the link works, i am new to dropbox also, here is another link to the paraview image of the alpha 1 and velocity
http://dl.dropbox.com/u/72086722/blo...ine_alpha1.png
http://dl.dropbox.com/u/72086722/blo...20velocity.png
Old   May 18, 2012, 03:12
Olivier
olivierG is on a distinguished road
hello,
You get negative alpha, but it's -6e-57 and i don't think your tolerance error is that small !
Anyway, you have a liquid phase fraction of 1e-10, which is pretty small. Have you run setFields in order to inititialyze ? or run for a longer time ...
regards,
olivier
olivierG is offline   Reply With Quote
Old   May 19, 2012, 05:04
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Also, doesn't the saline eventually mix with the blood? Because if it's not immiscible, interFoam is not the right solver to start with.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   May 19, 2012, 21:48
Kia
Thanks guys, I have run setFeilds to initialize the saline, but it still does not work. I have a feeling that this has to do with my mesh, because i ran the same setup on the pitzDaily by modifying the mesh and adding a second inlet.
And i also interFOAM with the same fluid property (water) and it gives me the same error. I am using interFOAM because although blood and saline are not immiscible fluids, i do not want them to mix. I want more of a flushing of the blood near the walls and i think interFOAM is the right one. However i will try to use TwoLiquidMixingFoam if there is a tutorial for that.
Old   May 22, 2012, 14:51
Kia
Thank you Anton and Oliver, TwoLiquidMixingFoam was the correct solver to use, I still get very low liquid phase fraction ( order of 0.002) but after running it for long time i get mixing and it finally comes out of the tip.
However i have a few question, If Dab diffusivity what is alphatab and where do i find these two values for blood and saline. Thank you
Old   May 23, 2012, 03:00
akidess's Avatar
Anton Kidess
See posts #33 and #34.
Old   December 12, 2013, 03:41
Faraj
Filankes is on a distinguished road
I had the same problem, solved it by setting alpha = 0.5 to the all field.
Filankes is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
