turbulence with chtMultiRegionFoam
Old   June 12, 2012, 10:20
Default turbulence with chtMultiRegionFoam
supercommandodhruv
dhruv is on a distinguished road
Hello All,
I have running a case, which involves using turbulence model with chtMultiRegionSimpleFoam solver. The run is always giving me a floating point exception. I am using kOmegaSST model for turbulence, and BC are wall functions at the walls. I tried to change the BC near the wall to fixedGradient or zeroGradient, but when I run the solver, it automatically updates my boundary file for k and omega to run time selectable wall functions, and creates alphat and mut file.
The error is given as follows.
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region solid for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
    Adding to rhoFluid
    Adding to kappaFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
    Adding to turbulence
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
#0  Foam::error::printStack(Foam::Ostream&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6  Foam::compressible::RASModels::kOmegaSST::F2() const in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#7  Foam::compressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#8  Foam::compressible::RASModel::adddictionaryConstructorToTable<Foam::compressible::RASModels::kOmegaSST>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#9  Foam::compressible::RASModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#10  Foam::compressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::compressible::RASModel>::NewturbulenceModel(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#11  Foam::compressible::turbulenceModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#12
 in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#13  __libc_start_main in "/lib/libc.so.6"
#14
Floating point exception
I am also attaching my BC for the fluid region. If I change the turbulenceProperties to laminar, everything works well. So, I guess, there is no problem in the domain and the mesh splitting in two regions.
Anyone with some ideas??
Regards,
Dhruv.
dhruv is offline   Reply With Quote
Old   June 13, 2012, 10:34
Default Solved
supercommandodhruv
Hello All,
I solved this problem today. In the p file of the fluid, one of the boundary conditions needs to be modified to run it correctly.
Incorrect:
fluid_to_solid
type calculated;
value uniform 0;
This is not working. I replaced it by zeroGradient. Now the case works. Can anyone suggest why the other one does not work?
Thanks,
Dhruv.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
