creat a parallelized solver
Old   June 12, 2012, 14:56
Default creat a parallelized solver
Raymond.Leoi is on a distinguished road
I am trying to create a reactingFoam solver with mpi. Even the head file, <mpi.h>, is included, the error takes place as follows,
reactingFoam.C:46:17: fatal error: mpi.h: No such file or directory
compilation terminated.
Any suggestion for this problem?
Raymond.Leoi is offline   Reply With Quote
Old   June 12, 2012, 15:07
Assistant Moderator
Bernhard Gschaider
The big question is: why do you want to parallelize a solver that is already parallelized?
Anyway: the compiler doesn't find the mpi.h. So: check the -I-options that are there
BTW: the only reason why one would want to "parallelize" reactingFoam is that you want to use it as one task in a bigger parallel-program. In that case you'll have a lot of fun as OF already calls MPI_Init and the call of the "overprogram" will lead to confusion. Correctly including headers will then be the least of your worries.
A New Solver for Supersonic Combustion nakul OpenFOAM Announcements from Other Sources 19 February 27, 2024 09:44
[Other] A New Solver for Supersonic Combustion nakul OpenFOAM Community Contributions 20 February 22, 2019 09:08
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
parallelized equation solver suan Main CFD Forum 1 August 16, 2002 04:51
