add a pssive scalar in turbulent flow
Like Tree9Likes
  • 2 Post By zxj160
  • 2 Post By morard
  • 1 Post By morard
  • 1 Post By sdharmar
  • 3 Post By morard
Old   June 14, 2012, 12:59
Default add a pssive scalar in turbulent flow
Jian Zhong
zxj160 is on a distinguished road
Dear foamers,
How to add a passive scalar transport equation in the turbulent flow (I use LES)? Is there any tutorials for this problem?
amuzeshi and niro2016 like this.
zxj160 is offline   Reply With Quote
Old   June 14, 2012, 15:14
niaz's Avatar
A_R
niaz is on a distinguished road
you can do the same thing in your code
fvScalarMatrix hEqn
fvm::ddt(rho, h)
+ fvm::div(phi, h)
- fvm::laplacian(turbulence->alphaEff(), h)
dpdt
- (fvc::ddt(rho, K) + fvc::div(phi, K))
hEqn.relax();
hEqn.solve();
thermo.correct();
define alphaEff() firstly then use it.
niaz is offline   Reply With Quote
Old   June 15, 2012, 02:44
Dejan Morar
morard is on a distinguished road
for a passive scalar you just have to write transport equation for it:
volScalarField kappaEff
"kappaEff",
nu/Pr + sgsModel->nut()/Prt
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(kappaEff, T)
call this, for example, TEqn.H and include it into your solver:
#include "TEqn.H"
Here, Pr is your Prandtl number, or Schmidt number, or whatever you want, and
you have to add this to the readTransportProperties.H
dimensionedScalar Pr
transportProperties.lookup("Pr")
dimensionedScalar Prt
transportProperties.lookup("Prt")
There is also one very nice tutorial:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
Regards,
Dejan
sbusmayer and amuzeshi like this.
morard is offline   Reply With Quote
Old   June 15, 2012, 08:03
Jian Zhong
sgsModel->nut()/Prt
Regards,
Dejan[/QUOTE]
Many thanks. And what does the 'sgsModel->nut()/Prt' mean? And also the turbulent-> alphaEff()?
Old   June 15, 2012, 09:26
Dejan Morar
'sgsModel->nut()/Prt' is turbulent diffusivity
sgsModel->nut() returns turbulent viscosity which is calculated inside your LES model
and
turbulent-> alphaEff() is effective diffusivity (turbulent + molecular).
You need turbulent diffusivity because you model turbulent scalar flux as a product
of turbulent diffusivity and a gradient of a filtered field.
amuzeshi likes this.
Old   June 15, 2012, 11:43
Jian Zhong
Many thanks. Make sense.
Old   October 31, 2012, 00:37
Default Adding Temperature equation to PimpleFoam
Suranga Dharmarathne
sdharmar is on a distinguished road
Hi Dejan and Foamers,
I am trying to add Temperature equation to pisoFoam solver to do LES. I found two differnt ways of writing TEqn.H
kappat = turbulence->nut()/Prt;
kappat.correctBoundaryConditions();
volScalarField kappaEff("kappaEff", turbulence->nu()/Pr + kappat);
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
TEqn.relax();
TEqn.solve();
and
"kappaEff",
turbulence->nu()/Pr + turbulence->nut()/Prt
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
TEqn.relax();
TEqn.solve();
Is there any difference between those two?
Where should I include the TEqn.H? Inside the PISO loop or after the corrector step?
I have seen some users in this forum have suggested to specify "kappaEff" in createFields.H file in the same way we do for T and p. In this case I think that we need to specify bounday conditions of kappaEff too.
Is this correct?
I am going to use Smagorinsky model for SGS modeling. I suppose that it is enough to specify U, p and T in the boundaries. It is so confusing to me that most of the tutorial cases specify nuSgs, nuTilda in the bounday.
What is the reason behind that?
Finally,
When we specify,
turbulence -> nut()/Prt
Does the solver know that nut=nuSgs for LES modeling?
Please help me.
Best regards,
Suranga.
sdharmar is offline   Reply With Quote
Old   October 31, 2012, 03:59
Dejan Morar
Hi Suranga,
there is no difference between those two ways, but if you ask me, use the second one. And usually you don't need TEqn.relax(); but I suppose that you can keep it if you want.
Include it after the PISO loop.
You can specify kappaEff in createFields.H and give it option IOobject::AUTO_WRITE,
so that you can post process it after the simulation is completed. You don't have to specify boundary conditions, and my personal opinion is that it's not necessary since the boundary conditions for kappa should be the same as for nu.
You are right, you don't have to specify nuTilda. It is required for some RAS models, but I can't remember which one.
Yes, solver knows that. Just check these lines in LESModel.H
//- Return the turbulence viscosity
virtual tmp<volScalarField> nut() const
return nuSgs();
Regards,
Dejan
Kojote, ykanani and amuzeshi like this.
Old   October 31, 2012, 12:35
Dejan,
Thank you very much for your help. I did a simulation of pitzdaily tutorial by using tempPisoFoam ( the solver that I made including temperature field) and got unacceptable results for the temperature field. I have attached all the files for my test case and my new solver files herewith. Could you please see whether I am doing right or wrong.
I am sorry that I can not attache other files in the forum. If you can give me your other email I can send them too.
Best regards,
Suranga.
Old   October 31, 2012, 17:26
Hi Dejan and others,
I solved the trouble. I will post all the things I did in this thread later. Thank you very much for your help.
Best regards,
Suranga.
Old   November 1, 2012, 04:17
Dejan Morar
Hi Suranga,
it's nice to hear that you have solved the problem.
Best regards,
Dejan
Old   January 27, 2013, 13:57
Default tempSimpleFoam.
  #12
Hi everyone,
I am really sorry for not replying you earlier than this. You can find how I did modified the simpleFoam solver to solve temperature equation in the following thread.
http://www.cfd-online.com/Forums/ope...tml#post404356.
Please don't hesitate to give your comments. Your comments are always welcome.
BR,
Suranga.
Old   January 26, 2019, 01:21
priyesh kakka
kakkapriyesh is on a distinguished road
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
TEqn.relax();
TEqn.solve();
and
"kappaEff",
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
TEqn.relax();
TEqn.solve();
Is this correct?
Finally,
When we specify,
Please help me.
Best regards,
Suranga.
hi, i guess this is similar to current buyoant Pimple Foam , my question is : If i am using LES along with it,will it filter TEqn? as LES does implicit filtering,and i want to use a test filter to implement variable prt in the code . any suggestion on how to do it?Thanks
kakkapriyesh is offline   Reply With Quote
Old   January 28, 2020, 12:11
Default Problems adding muEff either nuEff
  #14
Rosario Arnau
rarnaunot is on a distinguished road
Hi Foamers,
I'm trying to do the same thing but in twoPhaseEulerFoam and RAS turbulence model. Has anyone tried it?
Thanks in advance,
rarnaunot is offline   Reply With Quote
passive scalar
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 01:00
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 03:46
Patch a bubble inside turbulent flow Helmi FLUENT 0 February 4, 2011 04:54
Turbulent flow through hexagonal circular pipe yogesh@cfd Main CFD Forum 0 November 9, 2010 23:10
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
