Psat
Old   June 15, 2012, 10:16
Default Psat
Nabil MEAH
bluemind is on a distinguished road
I'm currently trying to implement the saturation pressure into the solver twoLiquidMixingFoam, so far what I have written is :
forAll(psat,celli){
if (ELSATl[celli] > 200.)
psat[celli]=cfit*exp(c1 + c2/(Tl[celli] ) +c3*log(Tl[celli]/one ) +c4*pow(Tl[celli],c5));
else
psat[celli]=0.*pfit;
But when I compile i get the following error message :
error: cannot convert ‘Foam::dimensioned<double>’ to ‘double’ in assignment
I've chosen the unit of the constant c1..c5 and one, such that they give a dimensionless term inside the exponential and the log function. But cfit has a dimension of pressure. Somehow when I withdraw the 'celli' term from psat I don't have any problem, but since I need to apply the temperature condition for all control volume, I feel like I have to keep (celli) this term.
Does anybody know how to solve the problem ?
bluemind is offline   Reply With Quote
Old   June 16, 2012, 08:56
Nima Samkhaniani
nimasam is on a distinguished road
1) define Psat as volScalarField
2) if you did! , then pfit is dimensionedScalar but
pSat[celli] is Scalar so! use pfit.value() or same for cfit you can use cfit.value()
P.S:
T has dimension
T[celli] has no dimension
.value() return only value not dimension
now you should handle it
nimasam is offline   Reply With Quote
Old   June 18, 2012, 04:53
Nabil MEAH
Thank you nimasam for your answer,
I've tried what you said and the message error message is the same, so I added .value() to the constant c2 and c4 since they are not dimensionless :
forAll(psat,celli){
psat[celli]=cfit.value()*exp(c1 + c2.value()/(Tl[celli] ) +c3*log(Tl[celli] ) +c4.value()*pow(Tl[celli],c5));
else
psat[celli]=0.*pfit.value();
The error message obtained is error: call of overloaded ‘log(double&)’ is ambiguous.
Do you have an idea of what the problem could be ?
Old   June 18, 2012, 05:26
Nima Samkhaniani
use
Foam::log instead of log
Old   June 18, 2012, 06:23
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
you need to put .value() on all c's. c1, c3 and c5 as well
niklas is offline   Reply With Quote
Old   June 18, 2012, 07:33
Nabil MEAH
Thanks you nimasan and niklas,
I have taken your advice and it works, this is what I wrote :
forAll(psat,celli){
psat[celli]=cfit.value()*Foam::exp(c1.value() + c2.value()/(Tl[celli] ) +c3.value()*Foam::log(Tl[celli] ) +c4.value()*Foam:ow(Tl[celli],c5.value()));
else
Multiphase flow and Phase change due to heat transferevaporation haghajani OpenFOAM Running, Solving & CFD 88 February 11, 2020 08:00
