pointZone to cellZone
Old   July 12, 2012, 11:05
Default pointZone to cellZone
Peter_600 is on a distinguished road
Hi Foamers,
how can I get from a pointZone a cellZone?
cheers Peter
Peter_600 is offline   Reply With Quote
Old   July 15, 2012, 07:58
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Peter,
I think you can use the setSet utility to do what you want.
Something like this:
start setSet in your case:
setSet
create a pointSet from your pointZone:
pointSet p0 new zoneToPoint yourPointZoneName
create a cellSet from the pointSet
cellSet c0 new pointToCell p0
quit setSet
quit
then create a cellZone from the cellSet:
setsToZones -noFlipMap
Now you will have a cellZone called c0 which contains the points from your pointZone yourPointZoneName.
I might have made a few mistakes with the syntax but it should do what you want with a bit of fiddling.
Best regards,
Philip
bigphil is offline   Reply With Quote
Old   July 16, 2012, 07:35
Thank you very much!
I ll give it a try!
cheers Peter
Old   July 16, 2012, 08:02
This works fine for a pointSet, which is in ./polyMesh/sets/.
In my case I have a pointZone in ./polyMesh and I like to have a cellZone out of it.
Old   July 16, 2012, 09:01
bigphil's Avatar
Philip Cardiff
Hi Peter,
The above method should work fine to create a pointZone from a cellZone. As I explained above, you must create a pointSet from your pointZone, then create a cellSet from your pointSet, then create a cellZone from the cellSet
i.e.
pointZone -> pointSet -> cellSet -> cellZone
Philip
Old   July 17, 2012, 03:33
Sorry it was my fault!
It works I will try to adapt it within my mesh class.
Thank you very much!!
[mesh manipulation] Selecting cellzone using cellSet in OpenFOAM-1.7.0 ggoggodak85 OpenFOAM Meshing & Mesh Conversion 0 April 25, 2012 05:48
porous media (cellzone) thisisit FLUENT 1 November 24, 2011 03:32
How to compute cellZone volume vinz OpenFOAM Programming & Development 11 August 2, 2010 17:38
[snappyHexMesh] How can I put snappy layers in a separate cellzone? overkligheten OpenFOAM Meshing & Mesh Conversion 1 April 5, 2010 09:18
operating on a specific cellZone ??? kdarc OpenFOAM 1 May 11, 2009 10:47
