simpleFOAM not giving steadystate solution
Old   July 18, 2012, 07:51
Default simpleFOAM not giving steadystate solution
aerospain
aerospain is on a distinguished road
Send a message via Skype™ to aerospain
Hi everyone,
I am running a grid convergence study on a 2D square cylinder by refining four times an initial coarse grid (by refineMesh). All grids have been run by 5000 iterations and each of them, besides the first one, start from a mapped solution of the final iteration (5000) of the previous coarser grid (done by mapFields).
My surprise came when opening in paraView the last two solutions (pictures attached) and the finest grid gave an "unsteady" looking solution.
Mesh04 the first picture and Mesh05 the other one.
Any hints, please?
Thanks!
aerospain is offline   Reply With Quote
Old   July 18, 2012, 08:15
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
We probably need a little more info such as schemes for example.
Depending on the Re the flow around a square will rarely be steady-state and you could simply have refined the mesh to such a degree that the numerics start behaving more transient since the fluxes wont be "damped" as much.
Its just an idea
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   July 18, 2012, 09:16
niaz's Avatar
A_R
niaz is on a distinguished road
Dear aerospain
you solved a case not steady state. simplefoam does not have problem. your test case physically is unsteady.
niaz is offline   Reply With Quote
Old   July 18, 2012, 09:43
aerospain
Its just an idea
Dear linnemann,
Thank your for your help. I was aware from the beginning that my "physical" problem is unsteady and the "computational" one as not capturing the whole extent of the physics.
But, as it is usually done in grid convergence studies, you first run a steady solution to define your mesh size, and the you run unsteady solutions to define your time step. Besides, I will need to compare steady solutions and time-averaged (unsteady) solutions in a couple of months.
What you mention about the fluxes goes along the lines of what I've been talking to some colleagues during lunch break.
I've decided to run two meshes in unsteady mode to check how the turbulence behaves and if I can observe anything "going wild".
cheers!
Old   August 1, 2012, 06:54
Primoz Ternik
ternik is on a distinguished road
Originally Posted by aerospain View Post
Dear linnemann,
cheers!
Aerospain,
defining the mesh size based on a steady state solution results is O.K., but as you said, you do not achieve steady state solution (results) because your case is time-dependent! From that point of view, I think your approach is (might be) not O.K.
In your case, I would:
1. perform the numerical modelling of time-dependent flow;
2. do some "premature" modelling to get the impression on the time-step and mesh-size scale;
3. choose fine enough time-step, fix it and do the grid dependence study (for a given/fine enough time-step) using three consistently refined meshes;
4. once the "optimal" mesh (giving the mesh-size independent reults) is determined, use three (or more, if needed) consistently refined time-steps to show (prove) that the solution obtained on a chosen mesh size is time independent.
In addition, I suggest to go through the following paper
A.S.R. Duarte, A.I.P. Miranda, P.J. Oliveira. Numerical and analytical modeling of unsteady viscoelastic flows: The start-up and pulsating test case problems, Journal of Non-Newtonian Fluid Mechanics, 154 (2008), pp. 153-169.
where the similar "issue" is resolved.
Cheers,
Primoz
ternik is offline   Reply With Quote
Old   August 6, 2012, 07:50
aerospain
Thank you Ternik,
Your step-by-step explanation asserts me on what I had in mind.
Just one comment, I've been able to produce (numerical) steady results by starting from zero time all the grids. Before, I was using the results of each coarser mesh as a restart point for the following finer mesh. This allowed for the disturbances present in the solution to build up and show the physical unsteadiness after the third finer grid.
Have a great summer!
C.
grid dependancy gueynard a. Main CFD Forum 19 June 27, 2014 21:22
interFoam solution tolerances mgdenno OpenFOAM 4 September 13, 2011 12:58
Neumann Boundary Condition for Poisson Equation solution in Polar Coordinates prapanj Main CFD Forum 2 July 30, 2011 19:07
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 04:34
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
