problem in running a modified solver
Old   August 8, 2012, 08:31
Default problem in running a modified solver
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi everybody,
I made some changes in buoyantSimpleFoam and I want to solve my problem with this new solver. the new solver name is buoyantSimpleFoamMod. I used wmake but the following errors appear:
mostafa@mostafa-desktop:~/OpenFOAM/mostafa-2.0.1/run/applications/solvers/heatTransfer/buoyantSimpleFoamMod$ wmake
Making dependency list for source file buoyantSimpleFoamMod.C
SOURCE=buoyantSimpleFoamMod.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam201/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam201/src/turbulenceModels -I/opt/openfoam201/src/turbulenceModels/compressible/RAS/lnInclude -I/opt/openfoam201/src/finiteVolume/cfdTools -I/opt/openfoam201/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam201/src/OpenFOAM/lnInclude -I/opt/openfoam201/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/buoyantSimpleFoamMod.o
In file included from buoyantSimpleFoamMod.C:46:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:56: error: no match for ‘operator-’ in ‘g - Foam::Vector<double>(((const double&)((const double*)(&0.0))), ((const double&)((const double*)(&1.0e+0))), ((const double&)((const double*)(&0.0))))’
/opt/openfoam201/src/OpenFOAM/lnInclude/dimensionSet.H:255: note: candidates are: Foam::dimensionSet Foam::operator-(const Foam::dimensionSet&)
/opt/openfoam201/src/OpenFOAM/lnInclude/dimensionSet.H:263: note:                 Foam::dimensionSet Foam::operator-(const Foam::dimensionSet&, const Foam::dimensionSet&)
/opt/openfoam201/src/OpenFOAM/lnInclude/dimensionedScalar.H:52: note:                 Foam::dimensionedScalar Foam::operator-(const Foam::dimensionedScalar&, Foam::scalar)
/opt/openfoam201/src/OpenFOAM/lnInclude/dimensionedScalar.H:53: note:                 Foam::dimensionedScalar Foam::operator-(Foam::scalar, const Foam::dimensionedScalar&)
/opt/openfoam201/src/OpenFOAM/lnInclude/scalarField.H:78: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::scalar&, const Foam::UList<double>&)
/opt/openfoam201/src/OpenFOAM/lnInclude/scalarField.H:78: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::scalar&, const Foam::tmp<Foam::Field<double> >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/scalarField.H:78: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::UList<double>&, const Foam::scalar&)
/opt/openfoam201/src/OpenFOAM/lnInclude/scalarField.H:78: note:                 Foam::tmp<Foam::Field<double> > Foam::operator-(const Foam::tmp<Foam::Field<double> >&, const Foam::scalar&)
/opt/openfoam201/src/OpenFOAM/lnInclude/labelField.H:54: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::label&, const Foam::UList<int>&)
/opt/openfoam201/src/OpenFOAM/lnInclude/labelField.H:54: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::label&, const Foam::tmp<Foam::Field<int> >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/labelField.H:54: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::UList<int>&, const Foam::label&)
/opt/openfoam201/src/OpenFOAM/lnInclude/labelField.H:54: note:                 Foam::tmp<Foam::Field<int> > Foam::operator-(const Foam::tmp<Foam::Field<int> >&, const Foam::label&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:61: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::UList<Foam::DiagTensor<double> >&, const Foam::UList<Foam::Tensor<double> >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:61: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::UList<Foam::DiagTensor<double> >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:61: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::tmp<Foam::Field<Foam::DiagTensor<double> > >&, const Foam::UList<Foam::Tensor<double> >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:61: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::tmp<Foam::Field<Foam::DiagTensor<double> > >&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:64: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::diagTensor&, const Foam::UList<Foam::Tensor<double> >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:64: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::diagTensor&, const Foam::tmp<Foam::Field<Foam::Tensor<double> > >&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:64: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::UList<Foam::DiagTensor<double> >&, const Foam::tensor&)
/opt/openfoam201/src/OpenFOAM/lnInclude/diagTensorField.H:64: note:                 Foam::tmp<Foam::Field<Foam::Tensor<double> > > Foam::operator-(const Foam::tmp<Foam::Field<Foam::DiagTensor<double> > >&, const Foam::tensor&)
/opt/openfoam201/src/OpenFOAM/lnInclude/vectorTensorTransformI.H:283: note:                 Foam::vectorTensorTransform Foam::operator-(const Foam::vectorTensorTransform&, const Foam::vector&)
/opt/openfoam201/src/OpenFOAM/lnInclude/quaternionI.H:273: note:                 Foam::quaternion Foam::operator-(const Foam::quaternion&)
/opt/openfoam201/src/OpenFOAM/lnInclude/quaternionI.H:279: note:                 Foam::quaternion Foam::operator-(const Foam::quaternion&, const Foam::quaternion&)
/opt/openfoam201/src/OpenFOAM/lnInclude/septernionI.H:190: note:                 Foam::septernion Foam::operator-(const Foam::septernion&, const Foam::vector&)
createFields.H:57: error: no match for ‘operator-’ in ‘g - Foam::Vector<double>(((const double&)((const double*)(&0.0))), ((const double&)((const double*)(&1.0e+0))), ((const double&)((const double*)(&0.0))))’
make: *** [Make/linux64GccDPOpt/buoyantSimpleFoamMod.o] Error 1
anybody knows what should I do? this is my first time that I make changes in a solver.
thank you
adambarfi is offline   Reply With Quote
Old   August 8, 2012, 10:15
Adhiraj
adhiraj is on a distinguished road
Can you post the part of the code that causes the problem?
You are trying to subtract something from the variable and that is not allowed, it seems.
adhiraj is offline   Reply With Quote
Old   August 8, 2012, 10:27
adambarfi's Avatar
Mostafa Mahmoudi
Dear Adhiraj,
in createFields.H I made this changes:
    Info<< "Calculating field g.h\n" << endl;
    volScalarField gh("gh", ((((g - vector(0,1,0)) & mesh.C()) + vector(0,1,0)) & mesh.C());
    surfaceScalarField ghf("ghf", ((((g - vector(0,1,0)) & mesh.C()) + vector(0,1,0)) & mesh.Cf());
but do you see any error!?!?
From where do you understand the origin of this error?
Old   August 8, 2012, 17:34
Nima Samkhaniani
nimasam is on a distinguished road
"g" is dimensionedVactor
so you can not add or subtract it form a vector!
so you should define a dimension for your vector
P.S.
this is error:
and solution is below it:
candidates are: Foam::dimensionSet Foam:perator-(const Foam::dimensionSet........
nimasam is offline   Reply With Quote
Old   August 9, 2012, 16:08
adambarfi's Avatar
Mostafa Mahmoudi
P.S.
this is error:
Thank you Nima,
dimensionedVector un
       "un",
       dimensionSet(0,1,-2,0,0,0,0),
       vector(0,1,0),
    volScalarField gh("gh", ((((g + un) & mesh.C()) & un) - un) & mesh.C());
    surfaceScalarField ghf("ghf", ((((g + un) & mesh.Cf()) & un) - un) & mesh.Cf());
and after wmake this errors appear:
createFields.H:61: error: expected primary-expression before ‘)’ token
In file included from /opt/openfoam201/src/OpenFOAM/lnInclude/doubleFloat.H:30,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/floatScalar.H:38,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/scalar.H:39,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/IOstream.H:49,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/Ostream.H:39,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/OSstream.H:40,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/messageStream.H:211,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/error.H:51,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/UListI.H:26,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/UList.H:365,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/List.H:43,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/labelList.H:48,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/UPstream.H:43,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/Pstream.H:42,
                 from /opt/openfoam201/src/OpenFOAM/lnInclude/parRun.H:35,
                 from /opt/openfoam201/src/finiteVolume/lnInclude/fvCFD.H:4,
                 from buoyantSimpleFoamMod.C:32:
/opt/openfoam201/src/OpenFOAM/lnInclude/products.H: At global scope:
/opt/openfoam201/src/OpenFOAM/lnInclude/products.H: In instantiation of ‘Foam::innerProduct<double, Foam::Vector<double> >’:
createFields.H:64:   instantiated from here
/opt/openfoam201/src/OpenFOAM/lnInclude/products.H:97: error: no type named ‘type’ in ‘class Foam::typeOfRank<double, -0x00000000000000001>’
createFields.H:64: error: no match for ‘operator&’ in ‘Foam::operator&(const Foam::dimensioned<Type>&, const Foam::GeometricField<Type1, PatchField, GeoMesh>&) [with Form = Foam::Vector<double>, Type = Foam::Vector<double>, PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh](((const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&)((const Foam::volVectorField*)mesh.Foam::fvMesh::C()))) & un’
/opt/openfoam201/src/OpenFOAM/lnInclude/wordI.H:167: note: candidates are: Foam::word Foam::operator&(const Foam::word&, const Foam::word&)
/opt/openfoam201/src/OpenFOAM/lnInclude/dimensionSet.H:281: note:                 Foam::dimensionSet Foam::operator&(const Foam::dimensionSet&, const Foam::dimensionSet&)
/opt/openfoam201/src/OpenFOAM/lnInclude/PackedBoolList.H:266: note:                 Foam::PackedBoolList Foam::operator&(const Foam::PackedBoolList&, const Foam::PackedBoolList&)
/opt/openfoam201/src/OpenFOAM/lnInclude/vectorTensorTransformI.H:293: note:                 Foam::vectorTensorTransform Foam::operator&(const Foam::vectorTensorTransform&, const Foam::vectorTensorTransform&)
/opt/openfoam201/src/OpenFOAM/lnInclude/quaternionI.H:289: note:                 Foam::scalar Foam::operator&(const Foam::quaternion&, const Foam::quaternion&)
/usr/include/c++/4.4/bits/ios_base.h:162: note:                 std::_Ios_Iostate std::operator&(std::_Ios_Iostate, std::_Ios_Iostate)
/usr/include/c++/4.4/bits/ios_base.h:124: note:                 std::_Ios_Openmode std::operator&(std::_Ios_Openmode, std::_Ios_Openmode)
/usr/include/c++/4.4/bits/ios_base.h:84: note:                 std::_Ios_Fmtflags std::operator&(std::_Ios_Fmtflags, std::_Ios_Fmtflags)
createFields.H:65: error: no match for ‘operator&’ in ‘Foam::operator&(const Foam::dimensioned<Type>&, const Foam::GeometricField<Type1, PatchField, GeoMesh>&) [with Form = Foam::Vector<double>, Type = Foam::Vector<double>, PatchField = Foam::fvsPatchField, GeoMesh = Foam::surfaceMesh](((const Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>&)((const Foam::surfaceVectorField*)mesh.Foam::fvMesh::Cf()))) & un’
thank you
Old   August 10, 2012, 15:52
Nima Samkhaniani
the error line is obvious from warning!
creatFields.H line 61! (why?)
if you look at it carefully you will find that you enter extra ","
omit "," after vector(0,1,0)
Error, running a modified version of twoPhaseEulerFoam foamer OpenFOAM Running, Solving & CFD 0 March 11, 2012 16:17
Compilation problem after modifying a solver. PetSul OpenFOAM Running, Solving & CFD 2 October 1, 2009 17:28
patching problem unsteady solver yellow-stuff Main CFD Forum 0 September 25, 2009 01:26
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 10:21
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
