Access to the velocity at boundary cells
Like Tree2Likes
  • 1 Post By ybapat
  • 1 Post By fedvasu
Old   August 21, 2012, 22:37
Default Access to the velocity at boundary cells
Wei Liu
mathslw is on a distinguished road
Hi all,
I want to use the velocity at boundary cells and velocity at the boundary face.
I found that this code "const fvPatchField<vector>& Up = patch().lookupPatchField<volVectorField, vector>("U");" could obtain the velocity vector at the boundary face.
Is there any similar code to obtain the velocity vector at the boundary cell? or other methods?
Many thanks!
Mathslw
mathslw is offline   Reply With Quote
Old   August 22, 2012, 00:21
Yogesh Bapat
ybapat is on a distinguished road
patch.faceCells() will give you list of cells adjecent to boundary. To get adjecent cell for a face, do patch.faceCells()[facei]. Using this cell id and volVectorField U you can access value of velocity in the cell.
Regards,
-Yogesh
ybapat is offline   Reply With Quote
Old   August 22, 2012, 02:33
Arne Stahlmann
Arnoldinho is on a distinguished road
Another way to directly access the patch-nearest cells is to use U.boundaryField()[patchi].patchInternalField(), whereas patchi is your patch id which is found using const label patchi = mesh.boundaryMesh().findPatchID("bottom").
Arnoldinho is offline   Reply With Quote
Old   August 22, 2012, 14:06
Wei Liu
Regards,
-Yogesh
Hi Yogesh,
According you your suggestion, I write the following:
const labelList cells = patch().faceCells();
vectorField Uac = Ua[cells];
Is that right?
Thanks!
Wei
Old   August 22, 2012, 14:08
Wei Liu
Do you mean "U.boundaryField()[patchi].patchInternalField()" is the velocity vector?
Thanks!
Wei
Old   August 22, 2012, 14:13
Wei Liu
Regards,
-Yogesh
Hi Yogesh,
const fvPatchField<vector>& Uf =
vectorField Uc = U[cells];
Is that right?
Thanks!
Wei
Old   August 23, 2012, 00:16
Yogesh Bapat
Hello Wei,
You need to loop over cellList to access value of individual cell.
forAll(cells,celli)
vector Ui = U[celli]
If you need directly field of boundary velocities, better option is suggested by Arne in his post.
Regards,
-Yogesh
Old   August 23, 2012, 10:53
Wei Liu
Hello Wei,
forAll(cells,celli)
Regards,
-Yogesh
Hi Yogesh,
Actually, I want to modify the boudary condition define in the adjointShapeOptimizationFoam. The original code is as following:
const fvsPatchField<scalar>& phiap =
patch().lookupPatchField<surfaceScalarField, scalar>("phia");
scalarField Un(mag(patch().nf() & Up));
vectorField UtHat((Up - patch().nf()*Un)/(Un + SMALL));
vectorField Uan(patch().nf()*(patch().nf() & patchInternalField()));
vectorField:perator=(phiap*patch().Sf()/sqr(patch().magSf()) + UtHat);
In this code, it uses the velocity on the boundary face and there is no loop. Then I want to use the velocity at the boundary cell, in the same way, I think there should not have any loop. Do you have any idea about that? Moreover, I also need the gradient of the velocity at the boundary cell, can I use volTensorField gradUc=fvc::grad(Uc) if Uc is the velocity at the boundary cell.
Many thanks!
Wei
Old   August 23, 2012, 14:12
Wei Liu
Hello Wei,
forAll(cells,celli)
Regards,
-Yogesh
Hi Yogesh,
Actually, I am trying to program a BC class.
I found that the following code could obtain the velocity at the boundary cell:
const volVectorField& Uc = db().lookupObject<volVectorField>("U");
What about if I want the gradient of this velocity at the boundary cell?
Thanks!
Wei
Old   August 24, 2012, 00:00
Yogesh Bapat
Hello Wei,
const volVectorField& Uc = db().lookupObject<volVectorField>("U") would give you velocity field over entire domain. To get at boundary you need to do as Arne suggested in his post
U.boundaryField()[patchi].patchInternalField().
About gradient I am not very sure, but I think you need to calculate it and then use it by accessing its patch internalField in the same way as for velocity.
Regards,
-Yogesh
saeed jamshidi likes this.
Old   August 24, 2012, 12:28
Wei Liu
Hello Wei,
Regards,
-Yogesh
Hi Yogesh,
Thanks for your reply!
If I use U.boundaryField()[patchi].patchInternalField(), the code would be:
vectorField& Uac = U.boundaryField()[patch()].patchInternalField();?
Since this is in the BC class, can I use patch() here?
When I compiled, I was told ‘U’ was not declared in this scope. Then how can I declare the U here.
Many thanks!
Wei
Old   October 3, 2012, 20:22
Default east and north cell values
  #12
hawkeye321 is an unknown quantity at this point
Is there any way (any function) to get the value of a parameter at the east and north of a specific cell?
hawkeye321 is offline   Reply With Quote
Old   November 22, 2017, 09:10
Default access to value of a quantity
  #13
A. Min
alimea is on a distinguished road
Hi
Basikly, how can I access to value of a quantity like U in a cell?
thanks
alimea is offline   Reply With Quote
Old   January 9, 2018, 18:17
fedvasu is on a distinguished road
Originally Posted by alimea View Post
Hi
thanks
const scalarField& UCells = U.internalField();
forAll(UCells,CellI)
UCells[CellI];
you can find it in many places in OpenFOAM source.
is that what you want?
alimea likes this.
fedvasu is offline   Reply With Quote
Old   January 9, 2018, 23:31
Smile
  #15
A. Min
UCells[CellI];
Yes, thank you my friend
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 11:57
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 21:18
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
