how to interpolate grad(p)
Old   August 31, 2012, 20:59
Default how to interpolate grad(p)
Lun Yu
victorconan is on a distinguished road
Hi, everyone,
I am new to openfoam. I wanna interpolate the grad(p) but I don't know how to do this. I tried to use fvc::interpolate(fvc::grad(p)), but it does not work. Could anyone do me a favor to teach me how to do this?
Thanks!
PS:I also tried to build a volScalarField and interpolate it, but it did not work. I tried this:
volScalarField surfP
IOobject
"surfP",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("zero",dimensionSet(0,1,-2,0,0,0,0),0.0)
surfP.internalField()=fvc::grad(p);
I suppose there is something wrong with the surfP.internalField()=fvc::grad(p), could anyone tell me how to correct it? Thanks!
victorconan is offline   Reply With Quote
Old   September 2, 2012, 17:04
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by victorconan View Post
Hi, everyone,
Thanks!
You want to have the value of the gradient on the cell faces, right? Have you considered doing this directly with snGrad(p)? (Mind that this is only the gradient in the direction of the surface normal. But that is the only one you're going to get anyway)
gschaider is offline   Reply With Quote
Old   September 3, 2012, 01:56
Bernhard
Bernhard is on a distinguished road
Also, it would help a lot if you gave some compilation errors. "It does not work" does not help us a lot. Are you sure you want your variable surfP to be of type volScalarField? As I understand, you want a vector on the faces, so then it'd be surfaceVectorField... Anyhow, the snGrad(p) is probably already what you need.
Bernhard is offline   Reply With Quote
Old   September 3, 2012, 05:44
Lun Yu
Thanks for your reply!
What I need is the interpolated pressure gradient. I have no idea whether the snGrad(p) is the interpolated value.
Lun
Old   September 3, 2012, 05:46
Lun Yu
Thanks!
I found what was wrong. now I use:
volScalarField gradp=mag(fvc::grad(p));
now no error occurs during the compiling.
Thanks again!
Lun
Old   September 3, 2012, 08:14
Assistant Moderator
Bernhard Gschaider
Lun
It's better. It is the grad on the face between to cell in the direction of the normal of that face. Basically this value was used to calculate the grad in the cell. Have a look in the programmers guide. Unless you want to have the numerical inaccuracies of the roundtrip (1. to cell 2. interpolate back to face)
Old   September 3, 2012, 08:24
Lun Yu
I wanna implement the rhie-chow interpolation, in which I need the interpolated pressure gradient. That means I have to calculate the grad(p) in the cell and then interpolate it to the surface. As you say, snGrad is used for grad in the cell, so it is another term in rhie-chow interpolation[rhie-chow interpolation is: U=U_interpolate-(1/rAU)(gradp-gradp_interpolate)].
interpolate
Interpolate in some points ivan_cozza OpenFOAM Post-Processing 2 April 22, 2009 08:58
Interpolate a boundary condition Xabi OpenFOAM Pre-Processing 0 April 9, 2009 04:23
overflow when interpolate initial result richard CFX 1 June 11, 2008 07:36
GradP in channeloodles nikos_fb16 OpenFOAM Running, Solving & CFD 1 September 4, 2007 10:52
Interpolate Stex CFX 2 June 30, 2003 08:04
