BC for pressure driven compressor cascade
Old   September 6, 2012, 06:38
Default BC for pressure driven compressor cascade
Matthew Wright
MattWright is on a distinguished road
Hi. I am currently doing a thesis where I am running a simulation on a cascade of compressor blades in OpenFOAM. The simulation is 2D and consists of 1 blade with cyclic boundaries on the top and bottom of the domain for the cascade effect. I am running a compressible, laminar case. I ran rhoSimplecFoam and adapted my case from the tutorial, and this runs fine with the BCs the same as the tutorial. However, when I try my own BCs it crashes. I want total pressure specified at the inlet and static pressure at the outlet. The velocity is driven by the pressure at and angle of 55deg at the inlet. Total temperature is also specified at the inlet. Here are my p, U and T files. Can someone tell me what I am doing wrong. Thanks.
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101300;
boundaryField
BC1_on_INLET
type totalPressure;
p0 uniform 101300;
value uniform 101300;
gamma 1.4;
BC1_on_LOWER_PERIODIC
type cyclic;
BC1_on_OUTLET
type fixedValue;
value uniform 88131;
BC1_on_PROFILE
type zeroGradient;
BC1_on_SYM1
type empty;
BC1_on_SYM2
type empty;
BC1_on_UPPER_PERIODIC
type cyclic;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
BC1_on_INLET
type pressureDirectedInletVelocity;
inletDirection uniform (1.428 1 0);
value uniform (0 0 0);
type cyclic;
BC1_on_OUTLET
type zeroGradient;
BC1_on_PROFILE
type slip;
BC1_on_SYM1
type empty;
BC1_on_SYM2
type empty;
type cyclic;
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
BC1_on_INLET
type totalTemperature;
T0 uniform 300;
value uniform 300;
gamma 1.4;
type cyclic;
BC1_on_OUTLET
type zeroGradient;
BC1_on_PROFILE
type zeroGradient;
BC1_on_SYM1
type empty;
BC1_on_SYM2
type empty;
type cyclic;
MattWright is offline   Reply With Quote
Old   April 26, 2013, 21:18
sqing
Sunxing is on a distinguished road
Hi Matthew,
I also want to simulate a cascade with same inlet and outlet BC as your. Do you have solved this problem? Please let me know any progress that you have made.
http://www.cfd-online.com/Forums/ope...-pressure.html
Regards
Sunxing
Sunxing is offline   Reply With Quote
Old   August 27, 2013, 03:02
Default floating point exception
Akash Sharma
akashjangid is on a distinguished road
Hey, I am also doing the same case. I have the same boundary condition.
After some iteration there is an error coming floating point exception. Does anyone has solved this kind of error
Thanks !!
akashjangid is offline   Reply With Quote
Old   August 29, 2013, 04:16
bscphil's Avatar
Phillip
bscphil is on a distinguished road
Thanks !!
Hey Foamer's,
by a pressure driven flow simulated with rhoSimpleFoam:
  1. check your initial conditions (e.g. don't set the initial value for U to (0 0 0), but to a small value like (0.1 0.1 0); just trying to set the initial value for p to your static pressure at the outlet)
  2. check your discretization schemes
  3. check your under relaxation factors
  4. check your solver settings
That's it for more information, please post your case as *.zip with the files: fvSchemes, fvSolution, thermophysicalProperties, RASProperties, BC's.
For your next post/problem, please, just characterize your case: solver, discretization schemes, turbulence model, mesh (y+values), fluid properties, physical properties (Mach-range) etc.
bscphil is offline   Reply With Quote
Old   August 29, 2013, 15:13
Akash Sharma
I changes the initial condition for velocity but still same error is coming. I have attached my case here.
Thanks!!
Old   August 31, 2013, 18:32
bscphil's Avatar
Phillip
Thanks!!
Your boundary conditions seem's to be right. Please post the terminal output of the last time steps. In which equation is the error ??
For your next try change your relaxation factors to:
relaxationFactors
    fields
        p    0.3;
        rho    0.05;
    equations
        U    0.7;
        k    0.7;
        epsilon    0.7;
        h    0.5;
and set
    transonic       false;
For better results, you've change the schemes from upwind scheme to a more non-diffusive scheme, e.g. linearUpwind or QUICK for the convective terms and decrease the relTol values for p and U,k,epsilon
Good luck
Old   September 8, 2013, 18:01
Default Difference in results
Akash Sharma
Hello bscphil
My simulation results are coming good now, but there is still one problem.
I have the results in fluent for same case(which are correct), but the openfoam results differ by a lot.
I have attached 2 screen-shot of Mach contour at 50 % span length for fluent and openfoam.
I have the same BC, but the velocity is coming much much higher in openfoam
Any suggestions for this ?
Thanks
Old   September 13, 2013, 10:55
Default Temperature Problem
Akash Sharma
I gave total temp boundary condition at my inlet
outlet
T0 uniform 517.5; ( 517.5 is the total temperature)
value uniform 517.5;
gamma 1.4;
But in the result my static temp is going as high as 580 k.
Why is the happening ? plz help me with this ..
Thanks
internal flow BCs: pressure driven versus velocity driven mihaipruna OpenFOAM Running, Solving & CFD 22 March 6, 2014 10:06
Lid Driven Cavity using Ghost Cell Method and in C++ illuminati5288 Main CFD Forum 0 August 12, 2011 22:05
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 01:55
How to simulate the fan driven by the airflow? Jason FLUENT 2 April 17, 2008 15:56
Practical/Industrial Appications of the Lid Driven GD Main CFD Forum 1 December 19, 2007 06:30
