Find where force is applied
Old   September 25, 2012, 20:16
Default Find where force is applied
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
I am using simpleFoam (of v2.1.1). I am trying to find where the forces are applied and have been outputing the forces and moments using the following in the controlDict:
functions
forces
type forces;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 1;
patches ( "Volume_0_Wheel-1" "Volume_0_Wheel-2" "Volume_0_Wheel-3" "Volume_0_Wheel-4" "Volume_0_Car" );
rhoName rhoInf;
rhoInf 1.205;
pName p;
UName U;
log true;
CofR (0.0 0.0 0.0);
It worked great and I got all the outputs in the forces\0\forces.dat file:
# Time forces( pressure, viscous ) moment( pressure, viscous )
997 ( ( ( -25.6521 1575.07 -2489 ) ( 0.0440792 73.7995 8.74441 ) ) ( ( -5215.72 15.0189 86.2846 ) ( -15.0971 -0.0198099 -0.124274 ) ) )
998 ( ( ( -25.6488 1575.07 -2488.99 ) ( 0.0442406 73.8003 8.74387 ) ) ( ( -5215.69 15.0191 86.2908 ) ( -15.0984 -0.0198765 -0.124476 ) ) )
999 ( ( ( -25.6506 1575.07 -2489.01 ) ( 0.0442343 73.8004 8.74362 ) ) ( ( -5215.72 15.0171 86.289 ) ( -15.0978 -0.02023 -0.124946 ) ) )
My problem is that I can't work out how to derive the x,y,z coordinates where the forces are applied to obtain the moment. I have been struggling for a couple of hours and have to admit that geometry is one of my many weak points... Any help would be appreciated.
Thanks in advance
Julien
julien.decharentenay is offline   Reply With Quote
Old   September 26, 2012, 02:53
colinB is on a distinguished road
Dear Julien,
I hope I got your question right.
But actually you posted your answer already:
CofR (0.0 0.0 0.0);
In my 'old' files (from OF 1.7.x) this was the reference point
used for the calculations of the moments
So in your case you chose the origin.
I hope I could contribute
regards
Colin
colinB is offline   Reply With Quote
Old   September 26, 2012, 06:46
Hi Colin,
Thanks a lot for your answer. I probably need to clarify a bit. I am trying to know the distance - or vector - that define where the force is applied to generate the moment - I am just after the distance in the y-direction.
Let me know if it is unclear.
julien
Old   September 28, 2012, 08:38
sail's Avatar
Vieri Abolaffio
sail is on a distinguished road
you have the moments referred to a defined point, in this case 0 0 0.
moment is force time distance.
to find the distance from your reference ponint do moment/force
http://www.leadingedge.it/
Naval architecture and CFD consultancy
sail is offline   Reply With Quote
Old   September 30, 2012, 20:53
Thanks a lot for your answer and comments.
My understanding is that:
- Forces are the integral over surface of p*Face_normal;
- Moment are the integral over the surface of p*Vector(CofR,Centroid)^Face_normal.
Based on the above, I was trying to inverse a system to get the y coordinate:
Mx = yFz - zFy
My = zFx - xFz
Mz = xFy - yFx
Just doing y = Mx/Fz was neglecting the effect of drag on the x-component of moment. I am unsure if the above is correct as it implies that MxFx + MyFy + MzFz = 0 (ie the moment is to be perpendicular to the Force), but when I calculate the expression based on the output from openFoam this is not true. So I am assuming that my interpretation is incorrect.
I am using a "work-around" using ParaView (http://www.cfd-online.com/Forums/ope...-parafoam.html) where I construct two expressions:
1) The forces: surface integral of p*Normals
2) The x moment of the z force: surface integral of coordsY*Forces_Z
The center of application of the z force is calculated as (2)/(1).
I noticed some differences in the forces calculated (order of 0.2% so negligeable). This seems to be doing what I need.
Kind regards,
Julien
Last edited by julien.decharentenay; September 30, 2012 at 21:20. Reason: Just wanted to clarify.
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
Time-averaged force in CFX rjmcsherry CFX 2 October 21, 2010 10:34
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
plotting force magnitude force Siemens 6 July 11, 2008 04:19
