what means?word::stripInvalid() called for word r For debug level (= 2) > 1
Old   December 3, 2012, 17:17
Default what means?word::stripInvalid() called for word r For debug level (= 2) > 1
immortality's Avatar
Ehsan
immortality is on a distinguished road
Mean and max Courant Numbers = 0.0995124 0.209916
deltaT = 4.7619e-08
Time = 4.7619e-08
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
swak4Foam: Allocating new repository for sampledGlobalVariables
smoothSolver: Solving for Ux, Initial residual = 2.37033e-06, Final residual = 2.45847e-17, No Iterations 3
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 1.45241e-16, No Iterations 3
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for e, Initial residual = 2.05419e-06, Final residual = 4.50787e-11, No Iterations 3
For debug level (= 2) > 1 this is considered fatal
Aborted
immortality is offline   Reply With Quote
Old   December 4, 2012, 11:18
Thumbs up
RZA
Engr.RZA is on a distinguished road
Hi Ehsun
What is your problem type, model setup and solver?
I think u should check ur model setup thoroughly if this error is coming before starting of iterations. If its appearing after some iterations then u can play with the relaxation parameters or check the quality of ur grid.
Good Luck
Engr.RZA is offline   Reply With Quote
reconstructPar --> fileName::stripInvalid() called for invalid fileName commandtouse adona058 OpenFOAM Bugs 34 December 8, 2022 21:27
under-relaxation factors -> level of residuals Zigainer FLUENT 19 July 21, 2017 16:53
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
reconstructParMesh not working with an axisymetric case francesco OpenFOAM Bugs 4 May 8, 2009 05:49
