how to create cyclic from 2 boundaries in Openfoam 1.7.1
Old   December 10, 2012, 06:19
Default how to create cyclic from 2 boundaries in Openfoam 1.7.1
vsflap is on a distinguished road
Hi everyone,
I wonder if you could help me please with the problem concerning cyclic boundary with OpenFOAM 1.7.1.
I have a quite simple geometry for an airfoil and would like to set up periodic boundary conditions on the 2 vertical boundaries. I'm trying to create the periodic boundary from 2 boundaries (''wall'') with createPatch but I've got errors:
Moving faces from patch new_wall0 to patch 7
Moving faces from patch new_wall1 to patch 7
Doing topology modification to order faces.
cyclicPolyPatch:rder : Writing half0 faces to OBJ file "new_wall_half0_faces.obj"
cyclicPolyPatch:rder : Writing half1 faces to OBJ file "new_wall_half1_faces.obj"
cyclicPolyPatch:rder : Dumping currently found cyclic match as lines between corresponding face centres to file "new_wall_faceCentres.obj"
--> FOAM Serious Error :
From function cyclicPolyPatch:rder(const primitivePatch&, labelList&, labelList&) const
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 1566
Patch:new_wall : Cannot match vectors to faces on both sides of patch
Perhaps your faces do not match? The obj files written contain the current match.
Continuing with incorrect face ordering from now on!
--> FOAM FATAL ERROR:
face 5240 area does not match neighbour 133908 by 0.00101172% -- possible face ordering problem.
patch:new_wall my area:0.000254184 neighbour area:0.000254182 matching tolerance:1e-05
Mesh face:264077 vertices:4((-0.0707825 -0.9 0.03) (-0.068948 -0.9 0.03) (-0.068948 -0.761442 0.03) (-0.0707825 -0.761442 0.03))
Neighbour face:392745 vertices:4((-0.0707827 -0.9 0) (-0.0707827 -0.761442 0) (-0.0689482 -0.761442 0) (-0.0689482 -0.9 0))
Rerun with cyclic debug flag set for more information.
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 179.
FOAM exiting
thanks
vsflap is offline   Reply With Quote
Old   April 25, 2013, 05:58
shadowfax is on a distinguished road
Originally Posted by vsflap View Post
Hi everyone,
FOAM exiting
thanks
Hi vsflap,
I am also having a similar problem. Were you able to figure out the solution ? It would be very helpful to me
shadowfax is offline   Reply With Quote
Old   April 25, 2013, 10:41
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi vsflap,
I think you made some mistake in defining cyclic BC. In my case i used it for straight channel where inlet and outlet are my periodic BCs. I defined as follows:
leftWall
type cyclic;
neighbourPatch rightWall;
faces
(0 4 7 3)
rightWall
type cyclic;
neighbourPatch leftWall;
faces
(2 6 5 1)
Hope this will help
Regards
Reddy
mmkr825 is offline   Reply With Quote
Old   April 25, 2013, 10:47
Hi Reddy,
I figured out the problem, it was in the grid definition in blockmeshdict. It works now
Also, can you tell me what boundary conditions did you use for p and U ?
I am trying to use the fan bc, but haven't figured it out yet. I have a laminar flow in a rectangular channel with a cylinder inside it.
Thanks!
Old   April 26, 2013, 03:30
Dear Shadowfax
I used cyclic type BC for p and U.
For p:
leftWall
        type            cyclic;
        nFaces          40;
        startFace       157960;
        matchTolerance  0.0001;
    fixedWalls
        type            zeroGradient;
    rightWall
        type            cyclic;
        nFaces          40;
        startFace       162000;
    frontAndBack
        type            empty;
For U:
leftWall
        type            cyclic;
        nFaces          40;
        startFace       157960;
    fixedWalls
        type            fixedValue;
        value           uniform (0 0 0);
    rightWall
        type            cyclic;
        nFaces          40;
        startFace       162000;
    frontAndBack
        type            empty;
Regards
M Reddy
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 10:24
Compatibility OpenFOAM 1.6 and 1.7.1 Ale_galleria OpenFOAM 2 September 20, 2010 09:14
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
create a hardcopy of boundaries in batch mode Fab Siemens 4 January 8, 2007 04:21
