Automatic wall functions for kEpsilon model
Old   January 13, 2013, 06:27
Default Automatic wall functions for kEpsilon model
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
I would like to be able to properly calculate the turbulent flows using the
standard kEpsilon model regardless of y+ value. In the OpenFOAM
implementations, I understand that I have to use the mesh such that
y+>30 when using the high Re turbulence model.
What approach should I take to my aim?
Is there anybody who has experienced the implementations of the automatic
wall function in OpenFOAM?
I would like to listen to voice of experience.
I would welcome any comments and suggestions.
Thanks in advance,
Fumiya
fumiya is offline   Reply With Quote
Old   January 15, 2013, 08:36
Roland
sylvester is on a distinguished road
Hi Fumiya,
It is my understanding that using nutUSpaldingWallFunction (for nut) will give you such a wall function. For k and epsilon you should keep the usual wall functions (i.e. kqRWallFunction and epsilonWallFunction, respectively).
regards,
Sylvester
sylvester is offline   Reply With Quote
Old   January 16, 2013, 09:28
fumiya's Avatar
Fumiya Nozaki
Thank you very much for your reply, sylvester. I'll have a try.
By the way, I found the article related to this thread:
http://www.opensourcecfd.com/confere...9_Kurenkov.pdf
Is there anyone who has used or implemented the wall functions described in it?
Are they more robust than the wall functions implemented in OpenFOAM?
Best regards,
Fumiya
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Are wall functions automatic in OF-1.5-dev? NickG OpenFOAM Pre-Processing 0 May 7, 2010 10:19
Wall functions tutlhino OpenFOAM Pre-Processing 0 July 2, 2007 05:04
