January 18, 2013, 23:13 |
Profile data - (x y z ux uy uz) at Inlet
Sagnik
Rep Power: 13 |
I wonder if there is a way to use profile data as inlet conditions in OpenFOAM. I mean I have a .dat file showing (x y z ux uy uz k epsilon) values at different points at the inlet which have come from very fine resolution measurements. I have attached an example velocity file as reference. I want to input this as boundary condition to a OpenFOAM simulation. I wonder how to do it. Would groovyBC work ? Thanks for all the help. Sagnik |
January 19, 2013, 07:41 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
But timeVaryingMapped might work for you (although you probably will have to reformat the data)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
January 19, 2013, 10:18 |
Sagnik
Rep Power: 13 |
Thanks for the information. It seems for time varying condition we can only mention (time Ux Uy Uz) ! Is there a way to input location details as well like (time x y z Ux Uy Uz) ! Thanks again.
January 19, 2013, 19:05 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Quote from the comment in the source file Code:
Foam::timeVaryingMappedFixedValueFvPatchField Interpolates from a set of supplied points in space and time. Supplied data in constant/boundaryData/<patchname>: - points : pointField with locations - ddd : supplied values at time ddd Points need to be more or less on a plane since get triangulated in 2D.
Pulsatile profile at inlet | Josyula | Fluent UDF and Scheme Programming | 4 | May 6, 2012 10:09 |
How to assign the inlet B.C using a bunch of data set for an unsteady problem? | ali8500 | CFX | 3 | March 28, 2012 18:41 |
Pressure Inlet Boundary Condition Profile | arapha | FLUENT | 0 | April 4, 2011 16:23 |
NON-UNIFORM VELOCITY INLET BOUNDARY PROFILE | MURAT | Main CFD Forum | 0 | December 30, 2003 21:08 |
create logarithmic wind profile for inlet | Murat | Main CFD Forum | 0 | December 30, 2003 00:45 |
