define volscalarfield
Like Tree1Likes
  • 1 Post By nimasam
Old   January 19, 2013, 02:57
Default define volscalarfield
v
vahidzanganeh is on a distinguished road
hi foamers
i have to want a volumetric heat transfer coefficient defined in my new solver.
i have the following:
volScalarField Hv
IOobject
"Hv",
runTime.timeName(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar
"Hv",
dimensionSet(1, -1, -3, -1, 0, 0, 0),
10000.0
forAll(mesh.C(),i)
Hv[i] = ((Nuseltv[i]*thermo.alpha()[i] * thermo.Cp())/pow(porousdim,2));
__________________________
comment:
alpha is volscalarfield
Cp is volscalarfield
porousdim is dimeter: defined in constant folder
porousdim porousdim [0 1 0 0 0 0 0] 0.00083;
The following error is generated executable file
parameter.H: In function ‘int main(int, char**)’:
parameter.H:98: error: cannot convert ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘double’ in assignment
line 98 is : Hv[i] = ((Nuseltv[i]*thermo.alpha()[i] * thermo.Cp())/pow(porousdim,2));
who can help me?
best regards
vahidzanganeh is offline   Reply With Quote
Old   January 19, 2013, 11:28
Nima Samkhaniani
nimasam is on a distinguished road
is Cp volscalarField or dimensionedScalar ?
however
if it is volScalarField, i guess it should be
thermo.Cp()[i]
also
porousdim is a dimensionedScalar, here you need just its value, so it should be
porousdim.value()
vahidzanganeh likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   January 21, 2013, 01:23
v
dear nima
thanks your reply
Cp is volscalarfield in basicThermo.H file
I have changed the formula of volumetric heat transfer coefficient but the error is
parameter.H:101: error: no match for ‘operator[]’ in ‘Foam::basicThermo::Cp()[i]
comment:
Hv[i] = ((Nuseltv[i] * thermo.alpha()[i] * thermo.Cp()[i])/pow(porousdim.value(),2));
and
error is
parameter.H:101: error: cannot convert ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘double’ in assignment
comment:
Hv[i] = ((Nuseltv[i] * thermo.alpha()[i] * thermo.Cp())/pow(porousdim.value(),2));
best regards
Old   January 21, 2013, 01:39
Nima Samkhaniani
you can use this setting:
volScalarField Cp1=thermo.Cp();
then use
Cp1[i]
Old   January 21, 2013, 04:14
Unhappy
v
thanks your reply
this problem was solved.
but with Info Cp and Cp1 in log file
cp=dimensions [0 2 -2 -1 0 0 0];
internalField uniform 1009.12;
boundaryField
cp1=dimensions [0 0 1.49095e-264 1.51456e-264 0 0 0];
internalField nonuniform 0();
boundaryField
why??
best regards
Old   January 21, 2013, 04:36
Nima Samkhaniani
Dear vahid
thats strange error, i've never seen this before
may its better you define Cp first as:
volScalarField Cp
IOobject
"Cp",
runTime.timeName(),
mesh,
IOobject::NO_READ,
thermo.Cp()
then use
Cp[i]
Old   January 21, 2013, 06:35
v
thanks your reply
I hope it takes time to thank.
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
