Is steady state solver grid dependent?
Old   March 21, 2013, 06:43
Default Is steady state solver grid dependent?
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi Foamers,
I am doing simulations on 2D rectangular channel by using steady state solver. I prepared my solver by modifying "simpleFoam" solver. The dimensions (length*breadth) of the channel are 0.143*0.0017 (m). My geometry has 500*10 grids in x- and y- directions respectively. When i run my solver with 500*10 grids, it is giving good results. But when I refine grids (say 600*15) or increase the dimensions of the channel, after running few iterations it is giving the following error.
Error:
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3   in "/lib/i386-linux-gnu/libm.so.6"
#4  pow in "/lib/i386-linux-gnu/libm.so.6"
#5  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#6  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) at /opt/openfoam211/src/OpenFOAM/lnInclude/GeometricScalarField.C:273
 at /opt/openfoam211/src/OpenFOAM/lnInclude/GeometricScalarField.C:349
#8  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
 in "/home/malli_reddy/OpenFOAM/malli_reddy-2.1.1/platforms/linuxGccDPOpt/bin/SBM25Foam"
Floating point exception
The geometry pass the checkMesh test. Could someone please help me to understand the reason for the error. Thanks in advance.
Regards
Reddy
mmkr825 is offline   Reply With Quote
Old   March 22, 2013, 08:33
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Could you upload your case?
Best regards,
Fumiya
fumiya is offline   Reply With Quote
Old   March 22, 2013, 08:44
Hi Fumiya,
Thanks for reply. My case is simple 2D channel.
My blockMeshDict:
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.001;
vertices
    (0 0 0)
    (173 0 0)
    (173 1.7 0)
    (0 1.7 0)
    (0 0 0.1)
    (173 0 0.1)
    (173 1.7 0.1)
    (0 1.7 0.1)
blocks
    hex (0 1 2 3 4 5 6 7) (1000 10 1) simpleGrading (1 1 1)
edges
boundary
    leftWall
        type patch;
        faces
            (0 4 7 3)
    fixedWalls
        type wall;
        faces
            (7 6 2 3)
            (1 5 4 0)
    rightWall
    type patch;
    faces
        (2 6 5 1)
    frontAndBack
        type empty;
        faces
            (0 3 2 1)
            (4 5 6 7)
mergePatchPairs
Regards
Mallikarjuna
Old   March 22, 2013, 10:56
fumiya's Avatar
Fumiya Nozaki
Hi Mallikarjuna,
Your mesh seems to be OK.
Could you share the files in 0 and system directories?
Best regards,
Fumiya
Old   March 22, 2013, 12:46
Hi Fumiya,
Very much thanks for your kindness. My solver is highly non-linear. In my solver i encounter shear rate(magnitude of strain tensor). So my solver needs good initial guess for velocity. So i am attaching my solver and case file with initial guess for velocity.
Solver:
https://www.dropbox.com/s/tm8i4y2u0a...M25Foam.tar.gz
Case File:
https://www.dropbox.com/s/bz7u10bc16urpdc/case.tar.gz
I am very thankful to you if you guide me in correct path. Thanks in advance.
Regards
Mallikarjuna.
steady state version of twophaseeulerfoam miles_davis OpenFOAM 17 March 31, 2020 05:36
coding a steady multiphase solver twophaseeulerfoam miles_davis OpenFOAM Programming & Development 6 February 6, 2019 16:25
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 04:59
error message cuteapathy CFX 14 March 20, 2012 06:45
grid adaption for unsteady solver matty FLUENT 3 July 18, 2005 13:16
