Natural convection over a single tube
Old   May 1, 2013, 14:18
Default Natural convection over a single tube
Ank
ankur
Ank is on a distinguished road
Hey Guys,
I am simulating a single tube of 325 mm length and 25 mm diameter kept inside a closed box of 2 m X 2 m X 2 m dimensions filled with air. I am simulating air as the perfect gas (compressible model). The tube is kept at 350 K temperature and air is at 300 K.
I am using buoyantPimpleFoam solver in Openfoam 2.0.0. The pressure is atmospheric at the tube and at the walls of the container, the velocity is no slip everywhere.
The problem is with the convergence, I am getting a fluctuating residuals for velocity and pressure. The residuals varies from 1e-02 to 1e-04, but it is not converging. The velocity vectors seems ok everywhere but the temperature range is showing 299.97 to 350 K, which should not go below 300 K (ideally).
I am taking a time step of 1e-05, and the meshing is tetrahedral (unstructured). I am using k-epsilon model as well as have tried SSTkOmega.
Please help me if you have any idea about this, I have tried every boundary conditions I could.
Thanks in advance
Ank is offline   Reply With Quote
Old   May 3, 2013, 11:07
Default nonOrthogonalCorrector
Fabian Roesler
fabian_roesler is on a distinguished road
Hi
How many nonOrthogonalCorrectors do you apply? With tetrahedral mesh you probably have to increase them. Could you post your fvSolution dict?
Regards
Fabian
fabian_roesler is offline   Reply With Quote
Old   May 3, 2013, 13:40
Ank
ankur
Hey
Thanks for your reply, I am posting my fvSolutions
| \\ / O peration | Version: 2.0.0 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"rho.*"
solver PCG;
preconditioner DIC;
tolerance 0;
relTol 0;
p_rgh
solver GAMG;
tolerance 1e-09;
relTol 0.001;
smoother GaussSeidel;
cacheAgglomeration true;
nCellsInCoarsestLevel 20;
agglomerator faceAreaPair;
mergeLevels 1;
minIter 1;
p_rghFinal
solver GAMG;
tolerance 1e-09;
relTol 0.001;
mergeLevels 1;
minIter 1;
h
solver GAMG;
tolerance 1e-08;
relTol 0.01;
mergeLevels 1;
minIter 1;
R
solver PBiCG;
preconditioner DILU;
tolerance 1e-08;
relTol 0.01;
U
solver smoothSolver;
nSweeps 2;
tolerance 1e-07;
relTol 0.01;
k
nSweeps 2;
tolerance 1e-07;
relTol 0.01;
omega
nSweeps 2;
tolerance 1e-07;
relTol 0.01;
"(U|k|omega|h|R)Final"
$U;
relTol 0;
PIMPLE
momentumPredictor yes;
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 0;
p 0.5;
U 0.3;
T 0.5;
k 0.5;
omega 0.5;
nut 0.5;
R 0.5;
nuTilda 0.5;
In one of the cases I had some fins on the same tube, I used nNonOrthogonalCorrectors = 4 and air as incompressible fluid, but in that case velocity was converging but p_rgh was not converging.
Plz have a look at it.
Old   May 4, 2013, 03:46
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by Ank View Post
Hey
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"rho.*"
solver PCG;
preconditioner DIC;
tolerance 0;
relTol 0;
p_rgh
solver GAMG;
tolerance 1e-09;
relTol 0.001;
mergeLevels 1;
minIter 1;
p_rghFinal
solver GAMG;
tolerance 1e-09;
relTol 0.001;
mergeLevels 1;
minIter 1;
h
solver GAMG;
tolerance 1e-08;
relTol 0.01;
mergeLevels 1;
minIter 1;
R
solver PBiCG;
tolerance 1e-08;
relTol 0.01;
U
nSweeps 2;
tolerance 1e-07;
relTol 0.01;
k
nSweeps 2;
tolerance 1e-07;
relTol 0.01;
omega
nSweeps 2;
tolerance 1e-07;
relTol 0.01;
$U;
relTol 0;
PIMPLE
nOuterCorrectors 1;
nCorrectors 2;
p 0.5;
U 0.3;
T 0.5;
k 0.5;
omega 0.5;
nut 0.5;
R 0.5;
nuTilda 0.5;
Do, something like this and let us know about the convergence.
PIMPLE
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 1;
pRefCell 0;
pRefValue 0;
relaxationFactors
fields
equations
"(U|T|k|epsilon|R)" 1;
"(U|T|k|epsilon|R)Final" 1;
You can also have a look at the tutorial/case folder of other heat transfer problems.
Also, try varying the "nNonOrthogonalCorrectors" upto 1 & 2. If still you are not getting the convergence then try to make quality (skewness for unstructured < 0.7) mesh.
Tushar@cfd is offline   Reply With Quote
Old   May 4, 2013, 07:30
Default outerCorrectors and relaxation
Fabian Roesler
Right. These settings look good for me too. Check your mesh quality. If you still have problems you could increase your outer correctors and give some relaxation factors.
Regards
Fabian
Old   May 4, 2013, 13:51
Ank
ankur
Hey
Thanks alot for your replies. I have updated my fvSolution accordingly in an already running case. The velocity residual is 1e-05 and pressure residual is 0.054, pressure residual is coming down with time. Hope to have it converged in some more time. I will post you accordingly after some time.
Once again thanks a lot for the help. One more thing I would like to ask, what is the significance of the outer correctors and non orthogonal correctors.
Ankur
Old   May 6, 2013, 07:13
T. Chourushi
Hey
Ankur
Check this out, for more information...
http://openfoamwiki.net/index.php/Ma...rGuideAddendum
Old   May 6, 2013, 07:30
Thumbs up Nice Page
Fabian Roesler
Nice, didn't know that page. Thanks.
Any news Ankur?
Regrads
Fabian
Old   May 7, 2013, 02:05
T. Chourushi
Any news Ankur?
Regrads
Fabian
You are welcome, even it is mentioned in the user guide of OF by Sir H. Jasak.
Old   May 7, 2013, 02:32
Ank
ankur
Hey
Sorry I got busy in some other work.
I have seen that page..not fully understood though. I will read it again and will let you know.
The case of tube having fins is now converging, the pressure has gone to 0.02 from 0.5..the convergence is slow. The grid quality is the problem I think, because the grid number is 1600000, mesh is tetra, and the skewness is around 1.1. I am using Gmsh 2.3.0 and I am not able to decrease the skewness below this value.
I am very thankful to both of you for your valuable suggestions and time.
I will post back as soon as possible with further updates.
Old   May 7, 2013, 03:05
T. Chourushi
Hey
Sometimes quality mesh really have an impact on results, may be with skewness of around 1.1 you may not get good results. Actually, order of >1 means you need to re-mesh your geometry.
So, it is usually advisable to keep skewness upto <0.8. For, that you need to really try hard in meshing. Spend sometime reading the same.
At last, the CFD solution depends on "Geometry meshing + solution algorithms" methods. So, you need to keep a balance between these, knowing only one method may cause problems in the results.
Old   May 7, 2013, 03:13
Ank
ankur
Hey Tushar
Thanks for the suggestion. I have tried a lot to decrease the skewness, and you are right I should try harder to make it good. I am going to do it first. I will let you know once I am done with it.
Ankur
Old   June 3, 2013, 04:10
Ank
ankur
Hey tushar
I am a little late for the reply. I have completed the CFd simulations of a cylinder without fins successfully. I got good results. In some time I will also simulate it with fins, hopefully It will also be done.
This reply is just to let you that its done and thanks for the help. I am facing some other problem wich I am going to post today on forum.
Thanks
Natural convection on finned tube kept in the open Ank OpenFOAM 2 February 20, 2013 22:56
natural convection in a vertical tube are_if Main CFD Forum 0 January 30, 2012 08:22
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
natural / free convection in a vertical tube Stephan FLUENT 0 November 10, 2006 13:07
Natural convection in vertical tube Ravi FLUENT 3 November 7, 2005 10:28
