MRF and employing on a propeller case
Old   June 10, 2013, 10:36
Default MRF and employing on a propeller case
reza1980's Avatar
reza
reza1980 is on a distinguished road
Hi Foamers,
I want to run MRFSimpleFoam on a propeller. The idea is using the tutorial on open foam ver 2.1x for mixer 2D and adapting for a propeller.
any body has idea in this regard?
reza1980 is offline   Reply With Quote
Old   June 11, 2013, 01:58
Nima Samkhaniani
nimasam is on a distinguished road
well to use MRF method, you need define an MRFzone
MRFzone should be a curvilinear such as cylinder , so it depends how you create your mesh , if you use snappyHexMesh, you can define your MRFZone in snappyHexMeshDict or you can assign a Zone by topoSetDict
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 11, 2013, 04:09
reza1980's Avatar
reza
Hi Nima,
I created mesh by 'pointwise' and doesn't need to use snappy one. Could you please inform me about the details of setup?
Old   June 11, 2013, 05:09
Nima Samkhaniani
well, i did not work with pointwise, you need to create two regions one internal region in cylinder shape which can be called rotor and one outer region which can be called stator, then add a MRFZoneDict to constant folder, then you should edit it for your case
Old   June 11, 2013, 05:40
reza1980's Avatar
reza
Nima,
This is my MRFzones dic .I arranged with my case but I still have error.
1
rotor
// Fixed patches (by default they 'move' with the MRF zone)
nonRotatingPatches ();
origin (0 0 0);
axis (0 0 1);
omega constant 104.72;
and the error
-> FOAM FATAL ERROR:
Cell 1995contains face labels out of range: 6(5845 5846 5847 -1 268241 5789) Max face index = 276219
From function polyMesh:olyMesh
const IOobject&,
const Xfer<pointField>&,
const Xfer<faceList>&,
const Xfer<cellList>&
in file meshes/polyMesh/polyMesh.C at line 652.
Old   June 11, 2013, 08:34
Nima Samkhaniani
can you run simpleFoam on this mesh, at all?
it seems something wrong is about your geometry, can you please send checkMesh result.
Old   June 11, 2013, 08:46
reza1980's Avatar
reza
I checked the mesh and the messege proves the mesh is ok.
Old   June 11, 2013, 09:09
Nima Samkhaniani
check whether simpleFoam run or not
Old   June 12, 2013, 06:15
reza1980's Avatar
reza
Nima,
I think my problem is to use setSet and to create cellZones .
THe meesge after applying setSet in OF2.2x is the command not found . and for ver 2.1 x is like below:
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.x-672d83ebe7be
Exec : setSet
Date : Jun 12 2013
Time : 12:14:07
Host : "beda.nfs.private"
PID : 19834
Case : /beda/users/home/rezame/OpenFoam/MRF
nProcs : 1
sigFpe : Floating point exception trapping - not supported on this platform
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time:0 cells:3562544 faces:9087761 points:2187990 patches:8 bb-17.9419 -7.20721 -5.16921) (10.582 7.20721 9.24521)
faceSets:
nonOrthoFaces size:10797
Time = 0
mesh not changed.
Please type 'help', 'quit' or a set command after prompt.
readline>
Old   June 12, 2013, 09:27
Nima Samkhaniani
Dear Reza
i guess you should define your zone in pointwise by defining two different regions which are separated by an internal face
Old   December 23, 2017, 11:29
Aldias Bahatmaka
bmaldi is on a distinguished road
Hello Nimasam
Do you know this problem?
When I run the simpleFoam on OpenFOAM I got the problems
https://drive.google.com/open?id=1Ea...ZsxzflO6H_8_fj
bmaldi is offline   Reply With Quote
Finner and coarser propeller case as parallel with different processors reza1980 OpenFOAM 0 April 25, 2013 06:02
