Uninstalling OpenFOAM and reinstalling fresh problem with dot files |
July 31, 2013, 04:05 |
Berns Buenaobra
Hello dear readers:
I have just got into this great forum for CFD - and was trying out a fresh reinstall of OF 2.2.x I don't know why I keep getting this message when I I have already deleted and uninstall OF when I reininstalled fresh again? Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. berns@linux-ephk:~/OpenFOAM/OpenFOAM-2.2.x> How do I get rid of older environment set-up that they don't stick like stuck for a fresh install? Thank you for any tip or help. Regards, |
July 31, 2013, 04:59 |
Artur
Rep Power: 20 |
I'm not a linux expert by any means but when I was installing a new version on my machine it sufficed when I edited my bashrc file:
gedit ~/.bashrc Code:
source /opt/openfoam220/etc/bashrc |
July 31, 2013, 09:38 |
Artur is right. The problem is in your bashrc file. You need to delete (comment out) everything regarding your previous OpenFoam installations.
Best, kilroy |
August 1, 2013, 02:36 |
Berns Buenaobra
Hello Arthur, Killroy:
Thanks for these replies. I actually did that quite several times and somehow it does not cut it?I still see these missing files or directory messages when I source bashrc ? I have resolved it by using "Bleachit" files and disk utility for Linux and wipe traces in memory in temporary folders and wiped the disk clean for the spaces recovered also -Im on OpenSUSE 12.3 by the way.I have successfully ./Allwmake my files again and build them in about an hour or so - then also ParaVIEW, openMPI etc. with success! This forum is quite neat I would say you get quite good replies and rapid too! |
