Laplacian(A*B)
Like Tree4Likes
Old   August 13, 2013, 02:28
Question Laplacian(A*B)
Richard
Ricardo is on a distinguished road
Hello, is possible solve in openFoam a function laplacian(k,A*B) where k is constant, A is known volScalarField and B is searched unknown (volScalarField)?
Thanks
Richard
immortality likes this.
Ricardo is offline   Reply With Quote
Old   August 13, 2013, 03:42
Bernhard
Bernhard is on a distinguished road
Did you consider fvm::laplacian(k*A,B)?
Bernhard is offline   Reply With Quote
Old   August 13, 2013, 06:22
Richard
Yes I did, but I don't know if it is correct from mathematical point of view.
I need solve this:
dF/dt=laplacian(delta,P)
P is partial pressure and could be rewrite F = P / Psat
Psat is partial saturated pressure (function of Temperature)
I tried this, but without succes...
fvm::ddt(dw,F)=fvm::laplacian(delta*Psat,F)
fvm::ddt(dw,F)=fvc::laplacian(delta,Psat*F)
Thanks
Richard
Old   August 13, 2013, 06:50
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
when you say tried, but without success....what does that mean?
Could you not compile it?
Could you not run it?
Did it not yield the desired result?
this should work and be your best bet...assuming Psat is just a constant.
just a note, but remember that
laplacian(k,AB) = div(k * grad(AB))
and is not, in general, equal to
laplacian(kA,B) = div(kA * grad(B))
only if A = const.
niklas is offline   Reply With Quote
Old   August 13, 2013, 06:53
niklas's Avatar
Niklas Nordin
also
= is an assignement
== is checking if its equal
so in that implementation you should use ==
Old   August 13, 2013, 07:00
Bernhard
Not always: http://www.cfd-online.com/Forums/ope...-operator.html
Old   August 13, 2013, 07:05
niklas's Avatar
Niklas Nordin
Originally Posted by Bernhard View Post
true
sorry, should have clarified that I ment in this example
Old   August 13, 2013, 07:11
Richard
I have operator "==" in code, it is right, compile and solution done, but result is wrong, I think.
I write solver for Heat and Moisture transport in porous materials.
1 step - Temperature calculation (changing thermal parameters with moisture)
2 step - Humidity calculation (changing moisture parameters with temperature)
next Iterations...
Saturated Pressure is not a constant, it depends on temerature and the temperature is changing in time. Transport parameters are calculated in time and stored in volScalarFields.
Thanks
Richard
Old   August 13, 2013, 07:32
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi Ricardo
how you have solved this equation?! with which solver of OF?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   August 13, 2013, 07:36
Richard
I started from basic Laplacian example, and still using PCG solver with DIC preconditioner, is it wrong?
Old   August 13, 2013, 07:46
Ehsan
No I just wanted to know.you are modifying the laplacianFoam,right? could you send me your case?
Old   August 13, 2013, 07:51
Richard
It is not problem, but it doesn't work correctly now, ...
Old   August 13, 2013, 07:56
Ehsan
I just like to know the way you are doing it.no problem.maybe an idea occurred to me.
my email is: force.of.love@gmail.com if you want to send it.
Old   August 13, 2013, 08:10
Richard
It has been send.
I am Ph.D. student, I would like use this program for simulations in my thesis. I wrote similar algorithm in 1D in Visual Basic, it works without any problem. OpenFOAM and C++ is new for me...
Richard
Old   August 13, 2013, 16:45
Default Dont forget the chain rule
  #15
Fabian Roesler
fabian_roesler is on a distinguished road
when psat is a function of temperature, you are not allowed to pull it out of the gradient in the laplacian function. But you could use the chain rule to get an implicit term of F and an explicit term of psat. Here we go:
Eqn (1): This is your starting point
    fvm::ddt(dw,F)
  + fvm::laplacian(delta,psat*F)
Eqn (2): Split the gradient term
    fvm::ddt(dw,F)
  + fvc::div(delta*F*fvc::grad(psat) + delta*psat*fvc::grad(F))
Eqn (3): Split the divergence term
    fvm::ddt(dw,F)
  + fvc::div(delta*F*fvc::grad(psat))
  + fvm::div(delta*psat*fvc::grad(F))
Eqn (4): form the last two terms into laplacians again
    fvm::ddt(dw,F)
  + fvc::laplacian(delta*F,psat)
  + fvm::laplacian(delta*psat,F)
Eqn 4 should work for you. Try it out.
Regards
Fabian
fabian_roesler is offline   Reply With Quote
Old   August 13, 2013, 18:02
Ehsan
whats dw in these equations while it isn't in dF/dt?
    fvm::ddt(dw,F)
    fvm::ddt(dw,F)
    fvm::ddt(dw,F)
how and why implicit terms convert to explicit ones and vice versa?
Old   August 14, 2013, 02:43
Fabian Roesler
Hi
The first laplacian
accounts for the change in saturation pressure and would be zero for constant psat. It has to be treated explicit (fvc), as the conservation equation is for F. The second term
can be treated implicit (fvm) now due to the chain rule.
Regards
Fabian
Old   August 14, 2013, 05:07
Ehsan
Hi Niklas, laplacian(A)=d^2A/dx^2+d^2A/dy^2 in 2D but what means above laplacian(k,AB)?if they are multiply why laplacian(k,AB) is different from laplacian(kA,B)?
Old   August 14, 2013, 09:56
Smile
  #19
Richard
Originally Posted by fabian_roesler View Post
    fvm::ddt(dw,F)
Regards
Fabian
Thank you very much, I am going to try it.
Yesterday I used other approach (similar which I using in Visual Basic) for implicit scheme and I think that results was correct.
- generate fvscalarmatrix "mat" from laplacian(delta,F)
- multiply each cell in fvscalarmatrix mat by Psat in point of this cell (using lduAddressing)
- solve (fvm::ddt(dw,F)==mat)
But this code is more complicated and your approach seems better.
dw is aproximation function of sorption curve (relation between water content and relative humidity of air) it is nonlinear function, I forgot write in equation
Richard
Old   August 14, 2013, 10:47
Richard
The part "fvc::laplacian(delta*F,Psat)" causes stability problem,...
volScalarField F
internalField nonuniform List<scalar>
4000
0.503748
0.500001
0.5
0.5
0.5
0.5
0.49999
0.44179
-361.167
-2.31903e+06
0.500001
0.5
0.5
0.5
0.5
0.5
0.49999
0.44179
-361.165
-2.31902e+06
