wall Function
Like Tree2Likes
  • 1 Post By cfdonline2mohsen
Old   September 19, 2013, 04:05
Default wall Function
Sasan Ghomi
sasanghomi is on a distinguished road
Hi Foamers,
I have a question about wall functions in openfoam.
I am using k-epsilon turbulence model and I am using kqRWallFunction and epsilonWalFunction . I think the range of Y+ should be between 30 and 300 30<Y+<300 . But in my case the range of yplus is Y+<10 . Please anybody guide me . Can I use another wallFunction with k-epsilon turbulence model? Is there enhanced wall treatment wall function in openfoam?? Can I change only wall function? Actually I want to use k-epsilon model But I want to have another wallFunction. Any idea?
I appreciate any help from you ,
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   September 19, 2013, 06:19
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Dear Sasan
Here is the source of all the incompressible RAS wall functions that are available in OF: wallFunctions
And they are only Standard wall functions.
So the easier way is to correct your mesh.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.”
cfdonline2mohsen is offline   Reply With Quote
Old   September 19, 2013, 09:01
Sasan Ghomi
Dear Mohsen ,
Thank you very much for your reply.I need compressible wall Functions . Do you know the Y+<5 is a good range ? {for standard wall function} ?
Best regards,
Sasan.
Old   September 19, 2013, 13:22
Mohsen KiaMansouri
Dear Sasan
You can find all compressible wall Functions available in OF in here: wallFunctions
As you told; the range of Y+ should be between 30 and 300 30<Y+<300 to use standard wall Functions. Coarsen the mesh in those zones where Y+ are less than 30 and refine the mesh where Y+ are more than 300.
There is another thing that you must notice when using yPlusRAS:
In the older versions of OF, this utility calculated yStar not yplus. I don't know if they fixed this bug or not.
see for example:
http://www.cfd-online.com/Forums/ope...earstress.html
http://www.cfd-online.com/Forums/ope...s-1-7-1-a.html
sasanghomi likes this.
Old   September 20, 2013, 03:17
Sasan Ghomi
Dear mohsen,
Thank you very much for your useful reply.
Do you know which version of openfoam have this problem? I am using 1.6 ext (CAE linux) I think the value of Y+ is very low in my case.
Old   September 20, 2013, 04:00
Mohsen KiaMansouri
Dear Sasan
Yeah, for OpenFOAM®-1.6-ext, it is Ystar not Yplus. have a look at:
https://github.com/Unofficial-Extend...RAS/yPlusRAS.C
and:
https://github.com/Unofficial-Extend...larField.C#L94
94      scalar yPlus = Cmu25*y[faceI]*sqrt(k[faceCellI])/nuw[faceI];
Which is the definition of Ysatr.
Old   September 20, 2013, 04:17
Sasan Ghomi
Can I fix this problem? Can you guide me for correction of code? Or Can you attach here the correct code?
I appreciate any help from you,
Old   September 20, 2013, 04:48
Mohsen KiaMansouri
As I told in post #4 see the below links for the correct code:
Problems with YPlusRAS and wallShearStress
Definition of y+ in yPlusRAS (1.7.1)
Old   September 21, 2013, 09:53
Sasan Ghomi
Hi Dear Mohsen,
I used the attached file in the #8 of below thread
I am using OP 1.6 ext so I changed option file :
- lgenericPatchFields------>>> -lmeshTools \
-lsampling
after compiling the code (wmake) I used this utility for my case But unfortunately I got zero value for all yplus everywhere . Please help me for getting correct code .
Sasan.
P.S. Also the attached file in #5 doesn't work for compressible flow.
Wall function for velocity? johnblund OpenFOAM 3 September 6, 2022 07:22
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 11:55
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Need some wall function approaches! yka8150 Main CFD Forum 0 September 21, 2009 23:08
