LRR turbulence model - initial condition set up
Like Tree1Likes
  • 1 Post By cfdonline2mohsen
Old   September 19, 2013, 14:46
Default LRR turbulence model - initial condition set up
Davide
Davide_sd is on a distinguished road
Hi all,
i'm looking for informations / tutorials / guidelines in order to setup a simulation with LRR turbulence model.
The paper i'm following provides me the turbulence profiles: \overline{u'u'},\overline{v'v'} and -\overline{u'v'}
I've seen its possible to define the R tensor with constant values. Is it possible to use profiles instead?
Davide_sd is offline   Reply With Quote
Old   September 20, 2013, 03:37
cfdonline2mohsen's Avatar
Mohsen KiaMansouri
cfdonline2mohsen is on a distinguished road
Dear Davide
About your last question:
Yes. it is possible. there are a lot of posts here in cfd-online regarding this matter.
search the forums for timeVaryingMappedFixedValue or swak4Foam.
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.”
cfdonline2mohsen is offline   Reply With Quote
Old   September 20, 2013, 03:54
Davide
i Know about the timeVarying...
my question is more specific...
if I want to use a profile for velocity, I create a file U for the velocity values in caseDir/constants/boundary data/inletPatch
what file should I create in order to declare turbulence stresses profiles?
Old   September 20, 2013, 06:43
Mohsen KiaMansouri
There is a tutorial in OpenFOAM which uses timeVaryingMappedFixedValue for inlet: pitzDailyExptInlet
your boundaryData must be something like this: boundaryData
you must add your R inlet Values to this folder: 0
And then in your 0 folder, specify
        type            timeVaryingMappedFixedValue;
        setAverage      off;
for R at inlet.
Old   September 20, 2013, 07:14
Davide
how am i supposed to separate the the three turbulence stresses profiles?
Old   September 20, 2013, 12:57
Mohsen KiaMansouri
R is a symmetric tensor that requires 6 components (not 3). have a look at the U in 0
write R according to it but with 6 components not 3.
lpz456 likes this.
inlet, lrr, profile, turbulence
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
Extremely slow simulation with interDyMFoam jrrygg OpenFOAM Running, Solving & CFD 9 April 23, 2013 10:14
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
