Wrong results after Modifying yPlus.C & OP 1.6-ext
Like Tree1Likes
  • 1 Post By nimasam
Old   September 22, 2013, 07:47
Default Wrong results after Modifying yPlus.C & OP 1.6-ext
Sasan Ghomi
sasanghomi is on a distinguished road
Hi Foamers ,
I am using OP 1.6-ext . I understood yPlusRAS have a bug and Actually it calculates Y* instead of Y+ . So I searched in the forums and I didn't find any correct yPlus.C for 1.6-ext . {there was some codes for standard versions}. I modified the yPlus.C for 1.6-ext and after compiling I checked this utility for a case but unfortunately I got zero values for Y+ everywhere in all times. I attached this code . Please anybody help me for finding the problem in this code .
I appreciate any help from you.
Thanks and best regards,
Sasan.
P.S. I only changed compressible and incompressible parts and I didn't change two phase part .
sasanghomi is offline   Reply With Quote
Old   September 22, 2013, 09:48
Nima Samkhaniani
nimasam is on a distinguished road
Dear Sasan
prepare a simple test case which we can examine your code there
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   September 22, 2013, 09:57
Sasan Ghomi
Hi Dr.Sam
I attached a cavity case that the solver of that is rhoPisoFoam so you should use yPlusRAS -compressible for getting Y+ .
Thank you very much
best regards
sasan
Old   September 22, 2013, 11:56
Nima Samkhaniani
Hello Dear Sasan
i feel the code should be like that :
yPlus.boundaryField()[patchi] =y[patchi]
* sqrt
//mut.boundaryField()[patchi]
(RASModel->mu().boundaryField()[patchi])
* mag(U.boundaryField()[patchi].snGrad())
/ rho.boundaryField()[patchi]
/ (RASModel->mu().boundaryField()[patchi]/rho.boundaryField()[patchi]);
actually i replace
with this:
i guess we should use mu in that equation not mut , however im not turbulent expert
Old   September 22, 2013, 14:03
Sasan Ghomi
I really appreciate your help and your attention replacing RASModel->mu().boundaryField()[patchi] eliminate the problem in the code.I think this formula is good for Y+<5 because when Y+ is lower than 5 So mut is very low comparing to mu . Do you know about order of Y+ in openfoam? is it similar to fluent or not ? Actually I can't set Y+ between 30 and 300 in my case (engine) .In my case the order of Y+ is low. So I want to set it lower than 5 and I want to know this order of Y+ in openfoam for standard wall Functions is acceptable or not ?
Anyway thank you very much Dr.Sam
Your help solved the problem.
Best regards,
Sasan.
Old   September 22, 2013, 14:11
Nima Samkhaniani
you can define muEff = mu + mut
However as i said before im not turbulent expert , so i dont know
sasanghomi likes this.
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
BuoyantBoussinesqSimpleFoam and axial-symmetric results wrong mass flow Thomas Baumann OpenFOAM 6 December 21, 2009 10:31
why dynamic mesh method give wrong results? weiyang1980 Main CFD Forum 0 September 22, 2009 21:06
[OpenFOAM] 'integrate variables' filter on a polyhedral mesh gives wrong results... jbf ParaView 0 September 4, 2009 04:08
