nNonOrthogonalCorrectors and accuracy of solution
Old   December 3, 2013, 15:12
Default nNonOrthogonalCorrectors and accuracy of solution
mechy is on a distinguished road
Hi all
I have created a high quality mesh around airfoil (2D quad mesh) with max non-orthogonality= 35
I have simulated it by fluent and openfoam and attached the drag coefficient.
as it can be seen, when nNonOrthogonalCorrectors is set zero the drag cofficient is completely different by its value when nNonOrthogonalCorrectors is set to 1
I will be so thankful if you tell me which solution is more accurate ?
Best Regards
mechy is offline   Reply With Quote
Old   December 6, 2013, 11:37
Travis Carrigan
tcarrigan is on a distinguished road
It looks to me like if you time-averaged the solution from the nNonOrtho=1 you'd get a result similar to nNonOrtho=0. However, you may want to continue running this case, it looks like it hasn't converged.
With a max non-orthogonality of 35, I'd say there is no need to use any explicit non-orthogonal correctors. Please see Hrv's comment.
Take care,
Travis
tcarrigan is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Accuracy in Boundary Layer solution in Fluent rameshbhoraniya FLUENT 3 September 7, 2013 02:26
Accuracy in Boundary Layer solution in Fluent rameshbhoraniya Main CFD Forum 0 September 7, 2013 00:57
Mesh quality and solution accuracy lalupp Main CFD Forum 0 April 3, 2012 07:45
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
