should I convert from FLUENT to OpenFOAM ?
Like Tree4Likes
  • 1 Post By Bernhard
  • 1 Post By olivierG
  • 1 Post By elvis
Old   December 11, 2013, 06:58
Question should I convert from FLUENT to OpenFOAM ?
Mamdouh
mrenergy is on a distinguished road
Hi OpenFOAMers , it is my first post in this forum
I used FLUENT and ICEM in my MSc to simulate the flow around airfoils,
now, I am in my PhD, working on Wind Farm Layout Optimization, I want to simulate the vertical wind speed profile in the Atmospheric BL considering the topology of the farm site, regardless the presence of the turbines,
do you see guys that OpenFOAM can handle this large scale problem better that FLUENT?
does anybody has an experience in both FLUENT and OpenFOAM, or has a fair comparison ?
do you suggest me to start learning OpenFOAM or to use my moderate experience with FLUENT ?
any contribution will be deeply appreciated ...
thanks for reading,
Mamdouh
mrenergy is offline   Reply With Quote
Old   December 11, 2013, 08:16
Bernhard
Bernhard is on a distinguished road
Well, there is no definite answer. There are a few things to consider
- Does your department have access to Fluent licenses (if so, how many?)
- Are you planning to do large parallel simulation? (this related to the previous one)
- How experiences are your direct colleagues with Fluent or OpenFOAM?
- Are you planning to do implementations in your model?
mrenergy likes this.
Bernhard is offline   Reply With Quote
Old   December 11, 2013, 15:58
Mamdouh
Thanks a lot, Bernhard, for your professional reply,
I expected that
YES,
NO, just I need the initial vertical wind speed profile at the farm site, based on the topology and terrains, to be used in power calculations,
most of us are FLUENT users, however, there are few OpenFOAMers,
NO,
I expect that you will direct me to FLUENT, am I right?
Best Regards,
Mamdouh
Old   December 12, 2013, 02:00
Bernhard
No, this is up to you to conclude, I just shared some issues that one should consider.
Old   December 12, 2013, 05:13
Olivier
olivierG is on a distinguished road
hello,
Since you are doing a PhD, you need to consider OpenFoam.
- If CFD is only a tools for your PhD, and you will never use CFD after, then the easiest way is certainly to use Fluent.
- If CFD are part of your thesis, you will learn far more things with OpenFoam, even if need to use Fluent afterwards.
regards,
Olivier
olivierG is offline   Reply With Quote
Old   December 12, 2013, 07:18
Elvis
elvis will become famous soon enough
There was "First Symposium on OpenFOAM in Wind Energy " unfortunatly the presentations are not online available anymore!
elvis is offline   Reply With Quote
Old   December 12, 2013, 12:36
Mamdouh
thank you, Olivier, for your contribution,
NO, CFD isn't a part of my thesis, I just want to use a more realistic vertical wind speed profile than the classical logarithmic or power law ones,
I spent a lot of time/effort with CFD in my MSc, I think it is enough
Regards,
Mamdouh
Old   December 12, 2013, 12:40
Mamdouh
thanks, Elvis, for the topic,
I will continue searching for the WindPower/OpenFOAM application to catch any of these publications
Regards,
Mamdouh
atmospheric bl, fluent, openfoam
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
convertion of openfoam .msh file to fluent pankos OpenFOAM 4 December 21, 2015 12:30
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
OpenFoam and Fluent compressible flowComparison sahm OpenFOAM 1 June 29, 2010 04:52
How to convert STAR mesh into FLUENT mesh ? Jihwan Siemens 8 November 10, 2004 04:11
