Using forces data in main() function
Old   December 13, 2013, 01:27
Default Using forces data in main() function
Geon-Hong Kim
Geon-Hong is on a distinguished road
Dear Foamers,
Good day foamers!
Recently I have tried to access data of forces object function to use as a criteria for convergence.
I made a header file including a static variable named Ftotal and make it to be included by both main solver program and forces class files. The force data estimated by forces object function is to be stored to the Ftotal static variable.
When I access the static variable Ftotal in the main program, it stores zero and I cannot use it at all.
Is there any idea to resolve this problem?
Thank you.
Geon-Hong.
Geon-Hong is offline   Reply With Quote
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 08:53
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
