New BC patch definition: typeInfo problem with refCast |
April 25, 2014, 17:40 |
Rep Power: 14 |
Hi everybody,
it was a long time without posting anything, but I always followed the developments of the Forum Now I'm facing a problem for which I didn't find a soution up to now, by reading other posts on this forums: I hope someone of you can help me, because it is a matter quite annoying to me. For the solver I'm modifing, I had the necessity to create a new BC, because I didn't find one to suit my needs. I modified the "compressible::turbulentHeatFluxTemperature" calling it "myGradientEnthalpy". Everything worked fine, I created a new library by means of the "make libso" command and I put the reference to it in 'controlDict' for my case. The problem arised when I decided to fix this BC in the createFields.H header using the refCast word; compiling the solver comes an error message in which seems "myGradientEnthalpy" is not recognized as a type. The error is generated inside the typeInfo.H header at line 110. As far as I understand, the problem could be solved with one of the macros listed in fvPatchField.H header and used to define a new type by means of typeDef and macro declarations, but I don't know how.; I didn't find yet a method to get the solver compiling process see my new BC even as a new recognized type to make refCast work. Could someone please give me a clue about this issue? Thank you in advance. Matteo Last edited by Matt_B; April 26, 2014 at 10:14. Reason: wrong reference to fvPatchFields.H |
April 26, 2014, 10:46 |
Rep Power: 14 |
I'm continuing here below the thread if someone is interested to:
http://www.cfd-online.com/Forums/ope...tml#post488381 |
fvpatchfields.h, patch type, type, typedef |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
