Negative Cell Volume with moveDyMEngineMesh with Foam Extend 3.0
Old   January 24, 2014, 03:29
Default Negative Cell Volume with moveDyMEngineMesh with Foam Extend 3.0
RJ HO
RJ87 is on a distinguished road
Hi foamers,
I manage to have this case running with older version of OpenFoam-1.6ext. But, it doesn't work with another computer of mine installed with Foam-Extend-3.0. I can't identify where is the different between older version OpenFoam 1.6-ext and Foam-Extend-3.0.
attached is a sample case and any help here will be greatly appreciated.
--> FOAM FATAL ERROR:
negative cell volume. Error in mesh motion before topological change.
    From function bool layerAdditionRemoval::changeTopology() const
    in file polyMeshModifiers/layerAdditionRemoval/layerAdditionRemoval.C at line 295.
FOAM aborting
Aborted (core dumped)
RJ87 is offline   Reply With Quote
Old   May 7, 2014, 19:23
virelli giuseppe
yvyan is on a distinguished road
Hi JR87,
I am finding problems similar to yours in migrating from 1.6-ext version to 3.0-ext version.
The dieselEngineDyMFoam solver that I created where I activated "layer addition removal" does not work properly anymore in 3.0-ext (on the other hand it works properly in 1.6-ext):
there is no layer removal even though "minimal thickness" < "removal threshold" and at the end the simulation crashes because of negative volume!
Did you solve? Have you got some suggestion?
yvyan is offline   Reply With Quote
Old   May 8, 2014, 12:13
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Speaking only from my experiences with getting the layerAdditionRemoval modifier to work in the official versions, I would check the mesh class you are using (seems like layerAR for the engineTopoChangerMesh type) is actually sending the signal to remove layers. The variable in the update() function is realDeformation I think.
mturcios777 is offline   Reply With Quote
Problem related to topology Ank OpenFOAM 3 May 2, 2012 05:08
Negative cell volume problem schuny FLUENT 8 April 10, 2012 05:16
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
