Cannot find patchField entry for wall????
Like Tree1Likes
  • 1 Post By Dream
Old   April 6, 2014, 21:54
Red face Cannot find patchField entry for wall????
Limx
Dream is on a distinguished road
We set up the separator model, and stimulates the multiphase flow. After we ran the setFields, the following information occurred:
Setting field default values
Setting internal values of volScalarField alphaair
Setting internal values of volScalarField alphawater
--> FOAM FATAL IO ERROR:
file: /home/dell/OpenFOAM/damBreak4phaseFinelmxlmx/0/alphawater.boundaryField from line 34 to line 56.
From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 206.
FOAM exiting
-----------------------------------alphawater-------------------------------------------
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alphawater;
dimensions [0 0 0 0 0 0 0];
internalField uniform 1;
boundaryField
Wall
type zeroGradient;
//value uniform 0;
new_new_out
type fixedValue;//;
value uniform 1;
new_out
type fixedValue;
value uniform 1;
out
type fixedValue;//outletInlet;
value uniform 1;
in
type outletOutlet;
outletValue uniform 0;
value uniform 0;
Maybe the boundary conditions were set incorrectly, but we didn't know how to revise them.
Thanks so much for help!
Dream is offline   Reply With Quote
Old   April 6, 2014, 22:45
xuhe-openfoam
bieshuxuhe is on a distinguished road
hi
if you use blockMesh to create the grid , please check the blockMeshDict !
maybe there is not a "wall" in the boudary.
may you success!
bieshuxuhe is offline   Reply With Quote
Old   April 7, 2014, 03:33
Limx
Originally Posted by bieshuxuhe View Post
hi
may you success!
Thanks so much!
We used the Gambit to model, and used the tool fluent3DMeshToFoam to convert.
Old   April 7, 2014, 04:01
Smile
Limx
hi
may you success!
thanks so much!
we have solved this problem. the reason is that we wrote the capital letter W with respect to the word wall.
6863523 likes this.
Old   December 8, 2016, 14:00
Bill Wang
6863523 is on a distinguished road
Originally Posted by Dream View Post
thanks so much!
Thanks so much. The OpenFOAM is so strict.
I also misused a capital letter for wall.
6863523 is offline   Reply With Quote
Old   October 14, 2020, 23:27
Sumit Peh
Jamessmp23 is on a distinguished road
hi
may you success!
Thank you, on my case is Inlet >> inlet
export geometry by Spaceclaim .stl with ASCII > cfmesh .fms > setFields solved.
Jamessmp23 is offline   Reply With Quote
calculating the viscous stress tensor tau for viscous dissipation heating dgadensg OpenFOAM Programming & Development 5 January 17, 2023 15:20
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
Problem Building OF on Centos cluster (no admin rights) CKH OpenFOAM Installation 5 November 13, 2011 06:32
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
A stupid question luckyluke OpenFOAM Running, Solving & CFD 14 August 13, 2007 04:25
