Simulating parts of the Polywell with openFOAM
Old   August 24, 2015, 14:17
Default Simulating parts of the Polywell with openFOAM
DrMattMoynihan's Avatar
Dr Matt Moynihan
DrMattMoynihan is on a distinguished road
Hello All,
In their recent paper, the EMC2 team listed the cusp confined volume as 5000 cm^3. That is crazy big. If that was shaped as a sphere, it would nearly fill the whole ring volume.
This is too scale. Here is my question: what is the magnetic field vector field outside this plasma volume?
There is an easy way to estimate this: treat the vector field made by the B field like a flowing fluid and solve it with some free CFD software. I would start with a two dimensional simulation.
I am trying to use simFLOW to do this CFD simulation. A couple of issues I am having:
1. Doing a 2D simulation does not seem possible (or easier) in simFLOW. I switched to 3D.
2. Fortunately, I can import the ring geometry into simFLOW using STL files.
3. How do I define the boundary conditions?
All the X-, Y- and Z- faces are planes of symmetry. But, the positive faces need to be broken up into “inlet” and “outlet” surfaces. How do I do that?
4. How do I mesh the space between the rings and the spherical surface only?
Thanks for the advice!
I would also like to transition to openFOAM to do the magnetic calculations, by MHD equations are half navier-stokes, so using the CFD solver seemed like a good stepping stone.
DrMattMoynihan is offline   Reply With Quote
boundary condition, openfoam, polywell, simflow
Tutorials on Simulating a Pitching Airfoil in OpenFOAM afrotimy OpenFOAM 4 January 18, 2018 09:20
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 12:25
Simulating Creeping (Stokes) Flow in OpenFOAM shanleyk OpenFOAM Running, Solving & CFD 3 July 9, 2015 15:41
Regarding setting Phases in simulating multiphaseflow in OpenFOAM harsha_kulkarni OpenFOAM Pre-Processing 0 September 28, 2014 01:53
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
