Simulating parts of the Polywell with openFOAM |
August 24, 2015, 14:17 |
Dr Matt Moynihan
Hello All,
In their recent paper, the EMC2 team listed the cusp confined volume as 5000 cm^3. That is crazy big. If that was shaped as a sphere, it would nearly fill the whole ring volume. This is too scale. Here is my question: what is the magnetic field vector field outside this plasma volume? There is an easy way to estimate this: treat the vector field made by the B field like a flowing fluid and solve it with some free CFD software. I would start with a two dimensional simulation. I am trying to use simFLOW to do this CFD simulation. A couple of issues I am having: 1. Doing a 2D simulation does not seem possible (or easier) in simFLOW. I switched to 3D. 2. Fortunately, I can import the ring geometry into simFLOW using STL files. 3. How do I define the boundary conditions? All the X-, Y- and Z- faces are planes of symmetry. But, the positive faces need to be broken up into “inlet” and “outlet” surfaces. How do I do that? 4. How do I mesh the space between the rings and the spherical surface only? Thanks for the advice! I would also like to transition to openFOAM to do the magnetic calculations, by MHD equations are half navier-stokes, so using the CFD solver seemed like a good stepping stone. |
boundary condition, openfoam, polywell, simflow |
Tutorials on Simulating a Pitching Airfoil in OpenFOAM | afrotimy | OpenFOAM | 4 | January 18, 2018 09:20 |
Memory protection in OpenFOAM / combinig with FORTRAN | botp | OpenFOAM Programming & Development | 2 | February 15, 2016 12:25 |
Simulating Creeping (Stokes) Flow in OpenFOAM | shanleyk | OpenFOAM Running, Solving & CFD | 3 | July 9, 2015 15:41 |
Regarding setting Phases in simulating multiphaseflow in OpenFOAM | harsha_kulkarni | OpenFOAM Pre-Processing | 0 | September 28, 2014 01:53 |
OpenFOAM Training and Workshop | Hrvoje Jasak | Main CFD Forum | 0 | October 7, 2005 07:14 |
